Steel Collar?
Discussion in 'The Garage' started by B_to_C, Jun 27, 2005.
  1. B_to_C
    B_to_C 1/2 ton status Author
    Jan 15, 2003
    1,861
    In Government Housing
    A while ago on here I read about a steel collar that clamps around the steering column so our trucks aren't as easily hot-wired. Anyone know what I'm tlaking about? I thought I remembered someone saying that Pep Boys carries them, but I have called up three local sotres and everyone thinks i'm crazy...
    Am I crazy? :crazy:
  2. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    I've seen them. It's more like a hinged casting that encloses the IGN key socket. The one I recall had a circular type key tumbler.
  3. B_to_C
    Jan 15, 2003
    1,861
    yup, that's what I'm looking for, I just need to konw where to buy it.... :confused:
  4. shane74
    shane74 1/2 ton status
    Feb 12, 2002
    4,100
    Vancouver, WA
    Put in an under dash ign. bypass. Much easier and cheaper.
  5. 1-ton
    Apr 17, 2004
    2,882
    161
    Las Vegas, Nevada
    I believe this is what you are looking for? These are supposed to be available from Pep Boys. I have two of them. One for my 1991 V3500 and my 1985 K30. I bought both of them from Pep Boys. I will try to get the Pep Boy Part number for you. Many of the pimple faced Pep Boy sales reps are not familiar with these Column Collor Locks.
  6. mrk5
    Apr 20, 2004
    12,332
    1,040
    Northern Colorado
    I've thought about modifying the base on my seat so that I can slide it up all the way against the steering wheel and lock it in place. No way to get the truck that way.
  7. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    the only thing I dont like about them is you have to take em off to start the truck with the key. Yeh I know its kind of the point, but moreso to keep em from busting the column. If I could leave it on there forever I wouldnt mind it, but taking it off and on everytime I park would get old. I know I would eventually quit, kinda like I did with the faceplate on my stereo.
  8. dyeager535
    26,979
    Problem is, if you can fit a key in, you can jam a screwdriver in there.
    To be honest, I'm not sure how effective a screwdriver in the lock cylinder would be, but the housing it sits in is plastic, so it might be fairly easy. Of course, it's just a lot easier to hammer the opposite side of the column, but if it's protected by the collar...
    Steadfast makes a "permanent" collar, but I'm not sure what they do about the key issue.
  9. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    ok, on steadfasts site now. http://www.steadfastautosecurity.com/steadfast.pdf They have you pry off the lock cylinder cap, put in some clutch, and then it also says if your key has a black plastic piece on it, you have to remove it, or the key wont insert. I wish they had a pic of the ignition side of their guard, but I cant find one.
  10. Cricket
    Cricket 3/4 ton status
    Nov 29, 2004
    8,224
    Colorado
    Hey Nick I just bought a Lock-Itt column lock. You can mount the collar permanently if you choose and then there's a secondary piece that fits over the ignition switch and bar that runs out past the steering wheel to keep it from turning.
    I'll post pics after installation tomorrow.
  11. 1-ton
    Apr 17, 2004
    2,882
    161
    Las Vegas, Nevada
  12. B_to_C
    Jan 15, 2003
    1,861
    1-ton.... you rock! :saweet: Thanks alot
    And Jiminy... Keep us updated :thumb:
