Steel grade question
Discussion in 'The Garage' started by sandawgk5, Sep 8, 2005.
  1. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    I was looking at some plate steel 3/8x3x17 it was 1018 cold rolled steel. My question is is this a good quality steel for making shackles and things of that sort out of?
    Ira
  2. tx_sub
    tx_sub 1/2 ton status
    Mar 5, 2004
    548
    Denton, TEXAS
    should do the trick
    check out matweb for material properties. lots of info there, but as with any internet source, there are variations and errors. i have had some different properties in some of my materials books than listed on the website. however, they were not too different to cause concern.
  3. tx_sub
    Mar 5, 2004
    548
    Denton, TEXAS
    pressure = force/area
    3/8" x bolt diameter
    force: say 1/2 the vehicle weight or more (factor of safety)
    yields psi
    compare to yield strength of the material in question. check the bolt as well (hint)
  4. sandawgk5
    Oct 28, 2003
    6,881
    Thanks I figured 9/16 hardware and used 3500 as a rough number for weight and came up with just under 18,000 psi. According to the link 1018 cold rolled is good to tensile yield of 53,000 psi so I think it would be ok to use.
    If I am wrong please let me know.
    Ira
