steel roller tip rocker arms?????
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by baldbandit, Jun 27, 2001.
  1. baldbandit
    baldbandit 1/2 ton status
    Jun 16, 2000
    282
    Marshall TX
    I am rebuilding my 350. It is bored .060 over w/ 202 heads and a performer cam. My question is, is it worth the extra money to buy steel roller tip rocker arms? What are the advantages and disadvantages of the roller tip and factory rocker arms?
    thanks
    baldbandit
    "Have you driven over a F@RD lately!!
  2. Wheels
    Wheels 1/2 ton status
    Aug 18, 2000
    638
    Less valve deflection, resistance and less chance of wearing out the guides. I'm running Comp Cams Magnum Roller Rockers and haven't had a problem. Won't notice much as far as hp gains, but it's a little added insurance.
  3. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I would say roller tips are a waste of money, although they'll save some valve guide wear. Go with full roller rockers.
    And I think you'll be sorry you chose the Edelbrock cam. Looking at the grind compared to the Comp XE and X4x4 cams it leaves much to be desired (it's much less agressive).
    Tim
  4. 502Burban
    502Burban 1/2 ton status
    Jun 8, 2001
    379
    Southern California
    Advantages to full roller-rockers are: 1) Reduced friction; 2) Reduced reciprocating mass; 3) Reduced side loading on your valve stems; 4) Improved reliability.
    Numbers 1 & 2 don't really make much difference on a lower revving engine like you'll find in most 4x4s, aside from less wear and tear over the long run. Big advantage in high revving race engines.
    Number 3 will lessen wear on your valve guides, due to the reduced side loads (again, less friction on the tip of the valve stem).
    Number 4 is mostly due to roller bearing at the trunnion (where it mounts to the rocker arm stud). It also allows much higher cam lift than a OEM slotted stamped steel rocker arm; again, not much benefit to a lower revving engine.
    The only disadvantage I can think of with roller-rockers is the high price: generally about $200 - $300 dollars. Well worth it to me, though. I always run Crane's roller rockers, although other brands are good, too. Crane's pieces just haven't ever failed me, so I figure, why switch? [​IMG]
    Robb
    '73 GMC Suburban - 502DFI
    <A target="_blank" HREF=http://community.webshots.com/user/robbrj>http://community.webshots.com/user/robbrj</A>
