Steel shims for the rear spring perches
Discussion in 'The Garage' started by willy s wagon, Sep 23, 2002.
  1. willy s wagon
    willy s wagon Registered Member
    May 28, 2002
    20
    craig, CO.
    Yay for me, 1st post! I broke, and or lost both shims on my rear springs this weekend, does anyone know where I can find steel ones to replace the broken alloy ones? If not, where do I find replacement shims? The lift kit manufacturer?
  2. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> This guy will make steel shims in any angle from 1-12 degrees for $25 per pair. Foothill Off-Road sells them in 2, 4, and 6 degree versions, but I don't know the price.
    1st post and already a member! Kudos! /forums/images/icons/wink.gif </font color>
  3. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    In the Burbs close to Tulsa, OK
    I bought a pair from the guy Shaggy mentioned in his post. I would not recommend using his. He basically cuts a steel block with a band saw. The shims were not the same thickness, but were the same angle. http://www.rockequipment.com/springs sells steel shims in multiple angles for $14.50each.
  4. willy s wagon
    May 28, 2002
    20
    craig, CO.
    Thank you both, I contacted Foothill's, they were the only ones open when I got off work. 32.00 including shipping, should be here and i'll install them on Tuesday.
