Steel
Discussion in 'The Garage' started by 1979jimmy350, Oct 25, 2006.
  1. 1979jimmy350
    1979jimmy350 1/2 ton status
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    I am looking to buy steel to make steering arms out of, what would be the best type of steel for this? Also where would i be able to by small blocks of steel?
  2. muddermilitia
    muddermilitia ThatTrazerGuy GMOTM Winner
    Nov 10, 2005
    5,742
    76
    NE Illinois
    I don't know what steel you'd want but I've bought stuff from Metal Supermarket in Elk Grove, IL. They have a lot of different metal but they are kinda pricey. there is also a race car builder in Rosco, IL called Lefthander chassis, I've bought some rect. tubing from them but I don't know if they would have the right thickness that you would need.
  3. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    honestly, dont waste your time. www.sky-manufacturing.com they've probably got exactly what you want sitting on the shelf. when i was there last month i couldnt believe it, i had never seen so many steering arms in one place before.
  4. 1979jimmy350
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    yea there still really expensive and i have acess to a mill and drill press's, its a lot cheaper for me to spend my free time on it than pay for it, im in college and don't have very much money to spend
  5. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    Then research it. There are good alloys and then there are better alloys for each application. You're going to need some special tooling though. Taper reams for both the TRE holes and the Cone Washer holes.
  6. 1979jimmy350
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    i know i need the reamers, i already have the one for the TRE/DRE on order, but i have no idea as to the taper that the cone washers use
  7. JK5
    Jan 31, 2002
    3,453
    Norton, Oh
    I've made them...it's easy.
    I'm making an arm for my g/f's rig, so she can have crossover.
    I used a 1 1/4" Hot roll low carbon plate, it has excellent machining qualities and it can be welded, if needed. I'm welding in a modified king pin cap to the arm.
