steer box adjustment .95 CHEVY ASTRO VAN AWD
Discussion in 'The Garage' started by 1BAD88, May 21, 2002.
  1. 1BAD88
    1BAD88 Registered Member
    Feb 23, 2002
    89
    bristol ct
    I need help locating the adjustment screw (if any) Is there a way to take play out of these boxes???? 95 CHEVY ASTROVAN. AWD 4.3
  2. TheLakeRat
    TheLakeRat 1/2 ton status
    Nov 29, 2001
    363
    San Angelo, Republic of Texas
    top of the box there is a plate with 4 bolt and a stud with a nut on it in the middle. using an allen wrench hold the stud and back off the nut with a 5/8" wrench a little. Now using the allen tighten the stud a 1/4 turn and then tighten the nut back down. Keep doing this untill the slack is gone. If your box gets to the pouint that you feel a tight spot in the or near the center of your steering arch then you need to back it off until the tightness is just barely gone.
  3. 1BAD88
    Feb 23, 2002
    89
    bristol ct
    I looked at the box on my k-5 and the one on the astro is different .it is mounted straight up and I cant see the adjustment screw .Is this the same type of steering box as our k-5s? any help is greatly appreciated thanks in advance.
