steering after 4" lift install?
Discussion in 'The Garage' started by chevystepside, Oct 21, 2003.
  1. chevystepside
    chevystepside 1/2 ton status
    Sep 23, 2002
    147
    leadville colo
    steering after 4\" lift install?
    i just installed a new 4" lift in my 89 k5. and installed a new steering arm that bolts to the knuckle for the 4" lift. now my steering seems to turn better to the left than to the right. what gives? do i just need to adjust my drag link or buy a drop pitman arm also?
  2. bryguy00b
    bryguy00b 3/4 ton status
    Apr 7, 2002
    5,587
    Rochester, N.Y
    Re: steering after 4\" lift install?
    do you mean turn more all together or what? little confused by what you said
  3. slimlynn1
    slimlynn1 1/2 ton status
    Apr 9, 2003
    336
    Hamden, CT
    You need to adjust your drag link. You will prebably notice that your steering wheel is not centered anymore. Adjust the drag link and you should be fine.
  4. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    Read my reply here to figure out how to fix this.
  5. bryguy00b
    Apr 7, 2002
    5,587
    Rochester, N.Y
    yea in that case you just loosen the two bolts on it and twist it till the wheel is centerd and the wheels are straight when wheel is.
  6. 87sm465np208
    87sm465np208 1/2 ton status
    Aug 28, 2002
    1,114
    illinois
    well, yep when i installed that stuff, all i did was loosen the bolts, use a screwdriver in that little slot and turn it, with the wheels stright, and have someone in the truck tell you when the wheel is straight, this is waht i did with my mom, she was in the truck, i was turning the thing, then my wheel was reasonably straight again /forums/images/graemlins/thumb.gif.
    /forums/images/graemlins/usaflag.gif /forums/images/graemlins/truck.gif
  7. chevystepside
    Sep 23, 2002
    147
    leadville colo
    cool i was hoping that it was just a drag link adjustment thanks to all that answered my post. time to go fix it. /forums/images/graemlins/thumb.gif
