Steering all funky, replaced almost everything, now what?
Discussion in 'The Garage' started by Pookster, Apr 20, 2003.
  1. Pookster
    Pookster 1/2 ton status
    Nov 21, 2000
    3,195
    NYC, NY, USA
    I've replaced almost everything in the front end... first put in the ORD brace, then replaced tie rod ends, ball joints, brakes, calipers, drag links, and the gear box. Steering is still kinda off. Very unstable. So I switched to new springs ( thinking that perhaps the bushings or something else was worn out there). Still screwy. The only thing I notice now is that when I turn the steering wheel left and right, be body moves. The body mounts are shot, could this be the cause of my problems?
  2. Silver84k5
    Silver84k5 1/2 ton status
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    i dont know what kinda suspension you are running, but you may need a panhard bar?
    or it may just be the body mounts, id check those first, cuz Panhard bars are usually just used on very flexy or very tall suspensions.
  3. Pookster
    Nov 21, 2000
    3,195
    NYC, NY, USA
    Overall lift is somewhere around 4-5 inches. Seen very few of our trucks using a panhard bar.. especially in the front. Especially seems weird since it's doing it in 2wd mode.
  4. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    In the Burbs close to Tulsa, OK
    Do you have a swaybar?
    My steering was really jacked. It wanted to wander all over the road. I thought I had it traced down to the WTO steering assist setup and was going to send that back. Then I thought to stiffen up my 9012s and that fixed the problem. Mine was wandering because of the body roll from not having a swaybar...
  5. Pookster
    Nov 21, 2000
    3,195
    NYC, NY, USA
    Yeah, I have a swaybar, hooked to the ORD swaybar disconnect. All the bushings are tight. Maybe too tight? Humm.
