Steering... Am I being too picky?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by dale_gribble, Jan 10, 2007.
  1. dale_gribble
    dale_gribble Registered Member
    Sep 20, 2006
    90
    Utah
    I am really being picky about my suburban V10, but I am starting to wonder if I am being unrealistic. It doesn't have any bumpsteer, and it's actually not that bad, but it just feels looser then I want it to...
    - I have had the steering box Warrior weld on 2 piece kit installed
    - Steering box bolts are snug
    - Dual brand new skyjacker steering stabilizers
    - New rag joint
    - Newly installed Borgeson steering shaft
    The ball joints are in great shape with no up/down play; there is what feels like a slight amount of slop on the drag link when the tires are off the ground, but I might just be being picky I don't know. There WAS about 1/8 turn of slop in the steering wheel before the Borgeson shaft. Now there is about 1/16 turn of slop.
    I am going to replace the drag link with the HD Napa Chassis Parts tonight and see how that feels... Tell me I am being neurotic and that it will never feel showroom tight ever again and I will feel better...
  2. BadBob
    BadBob 1/2 ton status
    Aug 14, 2005
    158
    Lyndon, KS
    You might have some slack in the actual steering box. That can be fixed.
  3. dale_gribble
    Sep 20, 2006
    90
    Utah
    The drag link ends were pretty shot. I think I found my culprit. I will find out tomorrow.
  4. sweetk30
    Nov 1, 2004
    25,537
    536
    horseheads , ny 14845
    put in a bolt in box brace kit. then sit back and fell the diffrence. when i installed my first one in my 10" lifted with 38 truck what a big big diffrence.
  5. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    X2, best mod I did.
  6. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Even with everything new , and all the bolt on and weld on mods , you will never get recirculating ball power steering totally tight . It ain't a 'vette :D
  7. roadnotca
    roadnotca 3/4 ton status
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    If your rig is hi-mileage, check the frame rivets. If they aren't solid, replace with weld or grade 8 bolts.:D
  8. PeteH
    PeteH 1/2 ton status
    Mar 26, 2003
    498
    San Jose
    i think...
    bolt in steering box brace
    tighten steering box itself
    get rid of rag joint go to jeep steering shaft
    crossover with all heims
    new powersteering pump.
    and either steering stabilizer or hydroassist with a small bore for quicker response.
    it would be great..
    does the steering act more responsive when in a turn? are you getting 1/16 when steering is centered? could it be the variable steering box at the point of minimal steer?
    just thoughts
  9. ccatlett1984
    ccatlett1984 1/2 ton status
    May 1, 2005
    161
    michigan
    Could you elaborate on the jeep steering shaft fix?
    Also, how do you tighten the box itself?
  10. muddermilitia
    muddermilitia ThatTrazerGuy GMOTM Winner
    Nov 10, 2005
    5,742
    76
    NE Illinois
    You can install the steering shaft from an XJ (cherokee) it will eliminate the rag joint. There is a writeup in the tech section
  11. koldsimer
    koldsimer 1/2 ton status GMOTM Winner
    Jan 10, 2005
    1,480
    texas
    I'll try to tell you how from what I remember. When you make the adjustment to the box you are just adjusting the play between the sector shaft and whatever the hell it connects with. There is a screw on top of your box with a locknut and an allen screw on top of it. Undo the locknut and turn the screw in 1/4 turn and see how it helps. If it doesn't help, turn it again. I had to make several adjustments to mine before it got tight. I have been warned that overtightening can ruin a box so be careful.
  12. dale_gribble
    Sep 20, 2006
    90
    Utah
    For me, it was the drag link after I did all of the mods like I previously mentioned. Thing feels awesome now. Tracks perfectly straight, no wander, good to go!
  13. roadnotca
    Sep 16, 2005
    5,433
    Redondo Beach, CA
  14. dale_gribble
    Sep 20, 2006
    90
    Utah
    Is that your site?
  15. roadnotca
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    Yes Sir. I haven't posted in "Vendors" yet.
