steering arm for x-over
Discussion in 'OffRoad Design' started by misfit, Mar 7, 2001.
  1. misfit
    misfit 1/2 ton status
    Jul 21, 2000
    324
    south central wa state
    should the tapered hole at the end of the arm be in line verticall with the hole for the tie rod? i saw a pic of your blazer and it wasnt in line. willl it affect me in any way?also, i noticed the end of the arm was milled at an angle, i assume its so the rod end stays 90 degrees when its hooked up? is that the best way?
  2. Chaz88K5
    Chaz88K5 1/2 ton status
    2,979
    Stockton/Lodi CA
    It shouldent make any differance....with the ball joint in there it is able to mount at almost any degree without a prob.
    Chaz
    "Hondas look good under a k5's tires"
