Steering arm on the knuckle.......
Discussion in 'The Garage' started by stallion85, Nov 12, 2004.
  1. stallion85
    stallion85 1/2 ton status
    Jul 11, 2003
    3,659
    Cedar City, UT
    How do you get that booger off? My bud got a lift with a raised steering arm and we can't get the old one off. I am thinking we might have to get some heat to it?
  2. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    Take off the 3 nuts and hit down on the top of it, near where the drag link hooks to it at. You may be able to remove the cone washers with a pliers/vice grips after you break them loose; remove by "unscrewing" them. I would avoid using heat as it will burn your balljoint boot.
    How do you have the vehicle supported?
  3. GMCLegacy
    GMCLegacy 1/2 ton status
    Jan 24, 2002
    620
    Grand Haven, MI
    do a search, lots of info here on the subject. to sum it up, you need a BFH. 4lb or more should sufice.
    id not recomend heat unless you want to do balljoints. the BFH swinging will most likely toll the upper balljoint as it is.
  4. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    Yeah, 4lb club hammer or bigger and punch it about. Hit it from all angles HARD and it will go. Once loose the conical washers should lift out and that's that! But DON'T put a raised arm on unless you've gone 6" + on the lift. Anything less will give you horrific bump steer.
  5. mudjunkie 82
    mudjunkie 82 1 ton status GMOTM Winner
    Dec 27, 2002
    11,449
    Cleveland Ohio
    Soak the hell out of it with PB blaster for a couple of days. The last one we did we took a wire wheel and cleaned all the rust off of the studs and cone washers. We heated the cone washers a little and took a small chiesel and hammer and worked the washers loose..................
  6. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    Mudjunkie /forums/images/graemlins/waytogo.gif....a blown 540!!!!! /forums/images/graemlins/yikes.gif /forums/images/graemlins/yikes.gif
    I would a thought you could of just fired up that motor and your steering arm would have run in fright!!!
