Steering arm placement
Discussion in 'The Garage' started by .308fanatic, Sep 1, 2005.
  1. .308fanatic
    .308fanatic Registered Member
    Sep 1, 2005
    11
    oklahoma
    Just bought a 79 Jimmy with 33x12.50x15 tires. Left front tire rubs the steering tie rod at the pitman arm when its in a hard right hand turn. What can I do about this? Maybe move the pitman arm one or two clicks forward? Thanks guys.
  2. txfiremank5
    txfiremank5 1/2 ton status
    Jul 6, 2004
    3,105
    San Antonio, TX.
    It seems odd that it would rub. What amount of back spacing are you running on your wheels?
  3. .308fanatic
    Sep 1, 2005
    11
    oklahoma
    back spacing
    None at the moment, I had a bad experience with spacers before. Have a set I was thinking about putting on, but would probably have to change lug studs.
  4. scrappy88
    scrappy88 1/2 ton status
    Mar 14, 2003
    314
    Loveland, CO
    Hmm the only way I could see it doing that is if you've got no lift on it, and running bigger tires with a lot of backspacing. Does it have a lift?
  5. .308fanatic
    Sep 1, 2005
    11
    oklahoma
    4" body thats it. I'm pretty good with motors, bad with front ends.
  6. txfiremank5
    Jul 6, 2004
    3,105
    San Antonio, TX.
    Actually, I'm not talking about spacers. Back spacing is the distance between the mounting surface of the rim, and the back of the wheel... (probably not the best explanation).
    Newer style wheels (on say a GM truck) have a bit of BS, while older wheels, and many aftermarket wheels, have a more "centered" mounting surface. If your running something with too much BS, then it will cause the tire to be located closer to the vehicle/axle and related parts. It's often that rubs will develope from that.
    Have any pics of the set up? It would help.
  7. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    i promise i'll be nice... :ignore:
  8. .308fanatic
    Sep 1, 2005
    11
    oklahoma
    Thanks for the explanation,txfiremank5 I'll look at the wheels tonight when I'm working on it. I'll try to get some pics later on.
