Steering arm question
Discussion in 'The Garage' started by wasted wages, Nov 19, 2004.
  1. wasted wages
    wasted wages 3/4 ton status
    Dec 3, 2003
    Dallas Texas
    My friend has a 78 LWB chevy that he had crossover steering
    installed on.The shop that did the work is now closed (go figure)
    When the steering arm was installed on the top of the knuckle on the pass side,, ( D 44 )the truck had 16.5 inch rims on it,,now when he tries to install 15 inch wheels the tire
    rubs on the end of the arm. what is the fix here another rim with a different offset or do they make an off-set steering arm that will give more clearance??
  2. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    Peoria, AZ
    Depends on the arm, but a rim with less BS should probably cure the problem. Running a narrower rim will probably help to if he runs a 12" rim or something like that.
    I run 4.125" BS rims what are 15x8's with no problems at all.
