Steering Arm Removal. Need Help????
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by Tuff, Apr 12, 2003.
  1. Tuff
    Tuff Registered Member
    Mar 4, 2002
    77
    Columbia, SC
    I can not get the damn thing off. Is there something I'm missing? I removed it from the ball joint. And, I removed the three nuts on top of the spindle. But I can't get the arm to break loose. Any, advise would be great. Thanks
  2. ECNiz
    ECNiz Registered Member
    Sep 9, 2000
    54
    Santa Cruz, CA
    Try Hitting the top of it with a big hammer, then the cone washers should loosen up a bit, take those out, and the arm will come off easy. Hitting it from the bottom won't really help till you get those washers out, it just makes them grab more.
  3. Tuff
    Mar 4, 2002
    77
    Columbia, SC
    Thanks I'll try that. I have been trying to just lift it off with every tool I own.
  4. blazerboy72
    blazerboy72 1/2 ton status
    Mar 29, 2002
    260
    hiram ga
    it seems to work best if you hit it on the very end where the joint goes
  5. jasonkh2tg
    jasonkh2tg 1/2 ton status
    Mar 27, 2003
    139
    MPLS MN
    I had the same problem..When installing my steering arm.First I removed the knucle and spindal then I used a blow torch to remove the steering arm..basically just melted it off...then put new studs in and cone washers and all metal lock nuts....then new ball joints...
  6. POFF
    POFF 1/2 ton status
    Aug 13, 2001
    221
    San Diego, CA
    I talked to the guys at the shop who built my rear-end and they said to soak the cones with penitrating oil (I prefer Aero-Kroil)and hit the arm with big ass hammer. I've done this a few times now and if you hit it hard several times it will pop loose.
