Steering arm removal..not
Discussion in 'The Garage' started by roadnotca, May 30, 2006.
  1. roadnotca
    roadnotca 3/4 ton status
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    185K miles, 20+ years, the cones do not pop-out. Ran out of drill bits for today. All I wanna do is replace the ball joint.:haha:
  2. rick88blaze
    rick88blaze 1/2 ton status
    Jan 24, 2003
    2,342
    Knob Noster, Mo.
    Soak it in PB Blaster and try beating down on the "U" part of the steering arm. I did that with mine and it came off in about 5 hits. :thumb:
    Rick
  3. sweetk30
    Nov 1, 2004
    25,544
    539
    horseheads , ny 14845
    you dont keen to remove that for a ball joint job.:doah: just need the correct adaptors.
    big 4-5 lbs hammer and solid steel punch. drive the old b/j out from the bottom. and dont be afraid to hit it.
    then remove boot from new and set in place and pull in with the press set the screw threw the lower hole and pull it in. then install the lower one.
    i do that all the time no problems.
  4. roadnotca
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    Lets see, I think that was Sunday. Yea, PB, support the steering knuckle on a jackstand directly on the garage slab, beat repeatedly with 8lb long handle sledge; nope, this is automotive root-canal. Its off a there tomorrow.:haha:
  5. roadnotca
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    Good idea, last Friday. Thanks guys. Read all the posts, gave it all due respect, too late now, only good for laughs. Its the Bubba way for this one.:haha:
  6. rick88blaze
    Jan 24, 2003
    2,342
    Knob Noster, Mo.
    I hope you are either able to get your ball joint changed or get the steering arm off either way. :thumb:
    Rick
  7. roadnotca
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    Thanks man.:D But yea, that arm is coming off, after that its only a couple hours to get back on the road.:laugh:
  8. roadnotca
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    Used about twenty drill bits to chew-out the cones.:haha:
