Steering Arm Removal
Discussion in 'The Garage' started by re42674, Aug 30, 2004.
  1. re42674
    re42674 Registered Member
    Oct 11, 2003
    9
    I'm trying to install a 4" lift on my 87 K5 and I can't get the steering arm to break away from the axle. I don't have a torch and I've tried everything from using gear pullers to a 2 lb sledge. Does anyone have any ideas on how to do this without having to find a cutting torch?
  2. daleearnhardt01
    daleearnhardt01 1/2 ton status
    Aug 29, 2002
    3,223
    Richmond, VA
    Ive never done it but everybody says to hit the arm with a sledge where the numbers are and it should come off..
  3. darkshadow
    darkshadow 1 ton status
    Dec 6, 2003
    12,250
    C-eh-N-eh-D-eh
    yeah the number thing is what i hurd too, try a propan torch to heat it up if it needs a little help /forums/images/graemlins/weld.gif
  4. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    If you used a 2lb sledge and it didn't work then get a 3lb sledge.
    It can take quite a bit of work to get them to come off. You have to beat the piss out of them sometimes. Hit it in both directions (upward and downward) and in different spots. If that doesn't work hit it some more. There a pain sometimes
    Harley
  5. re42674
    Oct 11, 2003
    9
    Yeah, we're still beating the hell out of it as I speak. I was just hoping that there was some other way because the sledge isn't doing too much. Actually, the sledge, which was purchased today just broke. This steering arm is a beast. Must have help. Thanks
  6. jwduke
    jwduke 1/2 ton status
    Aug 25, 2001
    721
    Ice Cream Capital of the World, IA.
    I did the "hit it on the numbers" thing, & it does work! /forums/images/graemlins/waytogo.gif
  7. re42674
    Oct 11, 2003
    9
    Where are the numbers actually at? Are they on the top or bottom, and are they out on the extended part of the arm (away from the bolts)?
  8. cochino12
    cochino12 1/2 ton status
    Dec 23, 2003
    563
    Parker, Co
    Yep thats where they are, on top away from the bolts. Spray a can of pb blaster on it and then put the bolts back about on half way. Then drive around the block, then take that sledge and smack the $hit out of the numbers. Mine popped off after about 5 smacks, good luck
  9. spearchucker
    spearchucker 1/2 ton status
    Nov 17, 2003
    1,556
    Bay area, CA
    Hit the arm on the farthest point from where it connects to the knuckle, right next to where the drag link connects. The reason you hit there is it gives you the biggest lever arm. You can also try putting a pair of vise grips around the conical washers and give the end of the vise grips a whack with a hammer in a counterclockwise direction. Just make sure you clean up the heads of the washers with a file before you reuse them.
  10. ugly_blazer
    ugly_blazer 1/2 ton status
    Apr 12, 2004
    1,214
    Is it off yet?
    How do you have the vehicle supported?
    I have taken many of these off. I've never owned a can of PB Blaster, let alone used it. I've gotten all of mine off with under a dozen good hits using nothing more that a decent size ball peen hammer.
  11. 1badv10
    1badv10 Registered Member
    Feb 26, 2004
    74
    new york
    i had the same situation on my truck. wound up taking the whole diff to my friends garage and putting a little heat on it while pulling on those cone washers and they came out like nothing.. after hrs of beating the snot outa that thing whith all kinds of BFH's /forums/images/graemlins/angryfire.gif... but the trick is to pull those washers then it just falls apart...hope this helps /forums/images/graemlins/waytogo.gif
  12. ugly_blazer
    Apr 12, 2004
    1,214
    I've always hit the arm with a hammer and removed the cones by hand /forums/images/graemlins/confused.gif
    I wouldn't use heat unless you enjoy replacing ball joint boots.
  13. 1badv10
    Feb 26, 2004
    74
    new york
    good point there those rubber boots do like to flare up huh /forums/images/graemlins/whistling.gif /forums/images/graemlins/whistling.gif i was debating replacing my ball-joints and that made up my mind for me.. my biggest problem was it was my first time doing it and had no idea what those washers were.(instructions that came with lift didnt show or explain) they just looked like lock washers and i figured they were just stuck to the studs /forums/images/graemlins/screwy.gif. but now that i know how they work i think i could do it alot quicker.. hope you'all got it apart.. i know your fustration but believe me the kit is worth it /forums/images/graemlins/waytogo.gif
  14. Yukon Jack
    Yukon Jack 1/2 ton status
    Jul 25, 2002
    1,984
    Rose Hill, KS
    I had to step up to a large sledge hammer, rather my small hand sledge hammer to get mine off - it was very difficult compared to the last one I removed. Must have had something to do with the truck being a rusted mess of junk! Ended up bending two of the studs so get to replace them too.
  15. re42674
    Oct 11, 2003
    9
    Thanks for the help. I got it off by using a air chisel/hammer to get the cone washers to start turning and then I used a pair of vice grips to turn them till they came off. Then I hammered the arm off. The reason I was having so much trouble is because I couldnt knock the arm up and off or get the cone washers to turn. Once I got them to turn, everything else came easy.
