Steering arm removal ?
Discussion in 'The Garage' started by la_blazer82, Jan 1, 2005.
  1. la_blazer82
    la_blazer82 1/2 ton status
    Apr 12, 2004
    148
    SoCal
    I'm trying to install a 4" extended steering arm and am having problems trying to figure out how to remove the 3 coned washers on the arm. I tried searching, but theads don't have any info or tips to remove. Thereare three nuts, which I already removed, that attach the arm to the knuckle on one end, and the TRE upper ball joint on the other end.
    These coned washers have a little slit that runs through it. I don't necessarily need to re-use these as I have others from the axle I'm swapping in
  2. AkMudr
    AkMudr 1/2 ton status
    Dec 30, 2004
    917
    Alaska
    Use a small chisel and punch them right down into the slit in the cones, that should drive them right up. Works every time for me.
  3. blublaz
    blublaz 1/2 ton status
    Nov 6, 2004
    145
    Tucson AZ
    I just remove the nuts, start the motor and work the wheel back and forth. A little juice works too, I prefer MGD. Throw some WD or rust free in there.
  4. Poohbair
    Poohbair 1/2 ton status
    Jan 30, 2003
    2,139
    Ellensburg, WA
    hit the arm DOWN w/ a big f'ing hammer, the cones will start to come up a little and you can pull them out w/ vise grips
  5. la_blazer82
    Apr 12, 2004
    148
    SoCal
    The nuts are already off, but the arm is still attached the the three bolts there. I've been banging a bit with a BFH and no luck yet. I'll try the other tips thanks. Anything else that works??
  6. smokkey1
    smokkey1 1/2 ton status
    Jan 7, 2004
    2,677
    Los Angeles, CA
    keep hitting hit, up and down, side to side.
  7. la_blazer82
    Apr 12, 2004
    148
    SoCal
    This thing is a be-otch! To top things off, came back from a week in Tahoe, and my neighbor tells me that Parking Enforcement has been taking pics of my drive way (K5 up in stands, and D44 sitting on side of driveway). I live on the corner of one of the main streets in Pico.
    If I could get this steering arm off, I could at least slide in the D44, and get the 10b out of the way and make it look decent enough that they wouldn't mess with me.
  8. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    I used a lagre breaker bar,as a wedge and a BFH. With a little movement, the air hammer went to work.Mine would not budge with just the hammer. A buddy tried a wood splitting wedge, but couldn't get the angle.
  9. la_blazer82
    Apr 12, 2004
    148
    SoCal
    Thank you for the tips. Gonna try all of these.
  10. anthony stark
    anthony stark Registered Member
    Jun 22, 2004
    31
    Houston
    I was in your situation. What has happened is they have compressed onto the threads.Unscrew them (like a nut) by tapping with a screwdriver in their groove.
  11. goldwing2000
    goldwing2000 Guest
    I was fighting with this thing this past weekend. Thanks for the tips!
  12. redneckdude
    redneckdude 1/2 ton status
    Feb 21, 2004
    578
    Augusta, GA
    You do have it down to the spindle on that side, don't you? I tried one day for a little whlie with the rotor on...didn't work well. Tried again with hubs and everything off and just beat the hell out of it from that side and one finally started to come up. Once you get one up, the other 2 will come out in no time.
