Steering Arm Removal
Discussion in 'The Garage' started by 1HighK5, Jun 21, 2005.
  1. 1HighK5
    1HighK5 1/2 ton status
    Feb 7, 2005
    140
    New York
    Can anyone tell me the best way to get the old steering arm off my D44 so I can put the new taller one on. I tried putting liquid wrench on it for like a week and a half with no luck. I have also tried heating it but didn't really get it too hot cuz I don't wanna mess up the ball joint. Can anyone gimme somthing else to try or trick or somthing. It's holding up the works! Thanks John
  2. 3rdshiftdesign
    3rdshiftdesign 1/2 ton status
    Feb 6, 2005
    259
    Bucks County, PA
    they're a pain. do a search. many other threads involving this same topic.
  3. beater74
    beater74 1/2 ton status
    May 29, 2001
    1,749
    atlanta
    i used a 3 pound sled and beat it up and then down repeatedly and it poped right off. but then again i had my axle out of my rig and i was really able to get a good swing on it.
  4. kgblazerfive
    kgblazerfive keymaster Premium Member GMOTM Winner
    Dec 2, 2004
    10,618
    609
    Hooper, Utah 84315
    Hit it from the side really hard till you think that your are hitting it to hard then hit it some more and the washers should work themselves up and loose.
  5. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    can you get the bolts off? what i do is use a 4 ft pipe, a craftsman breaker bar and a impact socket, that way if i braek the bar i can return it :D works every time, that amount of leverage just pulls thos nuts right around! as for the arm itself, see if you can get a jack just on the end of it, if you can jack the truck up on the tip of the arm and see if that loosens it, if the truck comes more than a few inches up off the ground and no luck then dont go any farther, you dont need a truck falling on you!
  6. 88Silverado
    88Silverado 1/2 ton status
    Mar 13, 2003
    2,664
    Quartz Hill, So. Cal
    It took me awhile to figure it out on my 88. After about 3 hours and nothing working someone told me the secret was to find the numbers that were stampped on top of the arm and take a 3lb hammer and hit it directly on the numbers. 3 hits and the cones popped up and arm popped off.
    Good luck
  7. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    i did this 2 weeks ago. after swinging a 3 lbs sledge for 30 minutes, i searched for my 4 lbs sledge (i was actually looking for my 15 lbs slege and found my 4 lbs that i wanted in the first place) like 5 swings with the 4 lb, i noticed that one cone washer moved. :eek: a few more swings and all 3 were off.
    moral of the story, get a bigger hammer :grin:
    i had the axle out of the truck also, gives you more swing.
    also i hit right in the crest of the arm, only down.
  8. Pookster
    Pookster 1/2 ton status
    Nov 21, 2000
    3,195
    NYC, NY, USA
    Step 1. Get mad
    step 2. find large blunt metal object
    Step 3. Beat the freakin daylights out of it.
    Step 4. Repeat until whole unit comes off.
  9. mr_blasto
    mr_blasto 1/2 ton status
    Nov 8, 2004
    495
    Irvine, CA
    :D :D :D This sucks!!! I can only smile cause I was beating on that thing for days thinking that I was doing something wrong. Some people said to try to stick something in the slit of the cone washers and hit down hard on that in order to force the cone washers further open which would get them loose and on their way out (in theory) - I broke some stuff using that approach and mangled the washer.
    The heat thing, yeah give it a try why not. At the end of the day you are going to have to do everything short of a mystikal steering arm removal dance to get it off (there is a lot of voodoo involved). Hit it on the numbers, hit it from underneath, hit it from the sides, hit it anywhere you can, but don't give up!!! You really have to beat that thing harder than you thought possible. Good Luck!
  10. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    I used a BFH and a breaker bar. Hit it, wedge the breaker bar it and hit that. Hit it again.
  11. resurrected_jimmy
    May 23, 2005
    2,241
    back home in Houston
    I'm laughing my @$$ off and feel your pain, My two cents is buy a BFH from sears so you can take it back when you break the handle off of it that's how hard you need to hit it
  12. stockk5
    Apr 13, 2004
    2,035
    71
    Cromwell, CT
    oh man this was the absolute most horrible part of putting my lift on, i wanted to kill someone, took about 2weeks of hitting w/ a 3lb hammer then my friend came over w/ his oxy torch and torched the sob off. The big thing is those conical washers. They are sooo tightly packed in there, you should try to find where the washer thing splits and try to make it spin with a punch and hammer. These washers suck cuz they go down around the stud into the steering arm. Goodluck!
  13. trailblazr81
    trailblazr81 1/2 ton status
    May 27, 2005
    931
    Hollister, CA
    But you gotta love the fact that this is THE way to get it off!! Its not the wrong way or means somethings wrong that you need to beat the hell outta it. I spent a couple hours beating with the 2 pounder. Then got the 4 pounder and started taking full swings with both arms...and FINALLY!! This was on my 81 a few years back. This weekend I will tackle my 73 K20. Should be fun. RIGHT!!! :haha:
  14. Scrubby
    Scrubby 1/2 ton status
    Dec 1, 2001
    114
    Boise, ID
    The up/down hitting is what worked for me. Seemed counter intuitive to hit it down, but that made all the difference. I beat on that thing up for 3 hours and it never moved.
  15. sunnyc123abc
    sunnyc123abc 1/2 ton status
    Mar 12, 2005
    636
    SoCal
    the way I did it was i took the knuckle or watever its called off the axle, then I carfully welded the bolt to the cone washer and just unscrewed it out. It was that easy. i tried to hit it out before but only one of the cone washers came out...but after welding the bolt to the washer it was just a matter of unscrewing it out.
  16. jekbrown
    May 19, 2001
    45,030
    365
    Vancouver, WA, USA
    this is why cone washers are the devil. I hate the things. I understand what they do, but my D60 arm stays on juuuust fine and it doesn't have a single cone washer on it. My toy buggy axles have them on the steering arm AND the hubs. good grief they are a PITA. Its pretty much my goal to eliminate their use on any axle I have, but every time I say something about "why even use them at all? they are a real PITA!" over on the pirate toyota thread and I get is stunned silence in return... as if I'm either crazy for wanting to get rid of them or there are no other options. bah!
    j
  17. trailblazr81
    May 27, 2005
    931
    Hollister, CA
    I think I will try the welding a nut idea this weekend!!! :saweet:
  18. 1HighK5
    Feb 7, 2005
    140
    New York
    Well thank you everyone for given me all the advice I forgot to mention that the axle is out of the truck and YES I will beat on it with my 5 LB lump hammer My favorite tool of my whole garage. But now I have a new problem I had just gotten the D44 a couple weeks ago for an easy 150 dollars and its in real good shape, It also beats the heck out of paying a GRAND for a D60 but now I found a guy with two D60's for 500 bucks each with the gears I want and all and he said he might even be able to do better on it I want it but now I gotta get rid of my D44 first O well
  19. 3rdshiftdesign
    Feb 6, 2005
    259
    Bucks County, PA
    email me information on one of those 60's ? info // at // atvguards.com -- if you could :D
