steering arm removal.
Discussion in 'The Garage' started by colbystephens, Jan 29, 2006.
  1. colbystephens
    colbystephens 1 ton status GMOTM Winner
    Feb 24, 2005
    10,924
    20
    Oregon
    ok. how do you remove the steering arm when it has decided that it doesn't want to be removed? how can i "persuade" it to come off? i doused it in wd-40 and pryed and hammered and it wouldn't come off the studs. i think i'm going to toss a match on it next and see what happens to the wd-40. someone send me a camera and i'll tape it. anyway - how do you get that thing off???? thanks.
  2. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    2wd or 4wd box ? Most of the time the arm on 4wd boxes just falls off when you loosen the nut all the way off the bolt , and actually remove the bolt from its slot in the shaft :thumb:
    ahhh on the axle itself , BFH works well
  3. mouse
    mouse 1/2 ton status
    Nov 10, 2003
    1,448
    Great Falls Mt
    If you're talking a 10 bolt or d44 arm on the steering knuckle, use a bfh, pound on each side, then up.
  4. rick88blaze
    rick88blaze 1/2 ton status
    Jan 24, 2003
    2,342
    Knob Noster, Mo.
    The ones I removed, I found the easiest way was to hit down on the "U" part of the arm with a BFH. It took a few hits and then popped off. :D
    Rick
  5. henry1986
    henry1986 Registered Member
    Jan 29, 2006
    13
    pa
    they make a pully for that
  6. Chaddy
    Chaddy 1/2 ton status GMOTM Winner
    May 23, 2005
    4,110
    Salt Lake City,Utah
    Ive taken off plenty, and yes they can take a minute or 2 but I have found the best way is to heat it up with a torch and use a big hammer.
  7. POWERMAD
    POWERMAD 1/2 ton status
    Mar 4, 2001
    3,466
    Oregon
    Cone pliers are yer freind.
    Smack one end till it starts to raise up and smack it back down, pluck out the cones and remove the arm.
    The longest it has taken me to get an arm off is 10 minutes and that was on a rig that had been on the coast.
  8. 81jimmyslt
    81jimmyslt 1/2 ton status
    Jun 5, 2003
    1,643
    So Lake Tahoe (Rubicon), CA
    We have a winner!
    Torch that sucker and expand the metal and bash that arm off.
  9. roadnotca
    roadnotca 3/4 ton status
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    I didn't understand the cone plier method. Looked at "cone pliers", jaws with lots of leverage. I stopped at that same point too, couldn't get the arm to let go, this truck had boatramp duty. If you get the cones, you'll need them, they are lead. When I get back to it, I figure to drill to relieve preload.
  10. colbystephens
    Feb 24, 2005
    10,924
    20
    Oregon
    well, i don't have access to a torch, and i have no clue what cone pliers are, but, on a positive note, i can get a big a$$ hammer! i'll try that. someone want to explain the cone plier thing to me?
  11. roadnotca
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    I tried MAPP-gas temp. and loading the truck weight on it, no go.
  12. Chaddy
    May 23, 2005
    4,110
    Salt Lake City,Utah
    oxyacetylene is the only way.
  13. roadnotca
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    Got it, it loosens the lead. That sounds like the answer Colby, either drill it hobby style, or soften the lead like a shop would.:bow:
  14. henry1986
    Jan 29, 2006
    13
    pa
    i had the same thing happen to me the arm wouldnt come off so i whent from the steering box an put on a drop down on
  15. henry1986
    Jan 29, 2006
    13
    pa
    i tried heat an all i put a 4inc drop down on for better steering
  16. colbystephens
    Feb 24, 2005
    10,924
    20
    Oregon
    sorry dude, i just don't understand. what would i be drilling? what is softening the lead? - by the way, who wants to ride in my truck when i'm done building it and ask questions like this?:wink1: i bet it will go really fast.
  17. POWERMAD
    Mar 4, 2001
    3,466
    Oregon
    Once the cones are unseated you will see that they are split, the pliers have a wedge that expands the cone and they pull right out.
    I use them all the time at work on semi drive axles, some have 8 of those suckers under the nuts and ya have to pop em out by smacking the axle flange with a 20lb hammer.
    OTC tools makes em, I got mine at NAPA for $10
    If ya can't find any localy swing by the shop and I'll sell ya mine and pick up another set, all the tool trucks carry them.
  18. henry1986
    Jan 29, 2006
    13
    pa
    i tried to use heat an had to replace balljoints not the best way to go
  19. colbystephens
    Feb 24, 2005
    10,924
    20
    Oregon
    another stupid question - the studs ar supposed to come out of the arm? what holds the arm to the knuckle?
  20. henry1986
    Jan 29, 2006
    13
    pa
    3 bolts
