steering arm removal
Discussion in 'The Garage' started by blaze4999, Apr 9, 2006.
  1. blaze4999
    blaze4999 Registered Member
    Feb 1, 2006
    14
    Quantico, VA
    I need help! I can't get my old rusted steering arm off my dana 44. I researched it and found that there are conical washers around the stud bolts. I don't know how to get them out. I've tried soaking it in wd 40 and beating it with a hammer. I was hoping someone knew a good way to get it off though.
  2. sweetk30
    Nov 1, 2004
    25,536
    533
    horseheads , ny 14845
    minimal hammer is 4lb and up. just rail it good a few times at the ends and she should pop up a bit.
  3. Janitorjim8
    Janitorjim8 1/2 ton status
    Feb 21, 2005
    215
    Illinois
    You might want to soak in something better then WD-40, maybe PB Blaster or another pentrating lube. You're gonna have to use something bigger then just a regular hammer, I used a 5lb sledge hammer on mine, hit down by where the tie rod end would connect. Be prepared to hit for a while, especially if they salt out there.
  4. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    PB Blaster. 8lb sledge. Wedge. Time, time,.........
  5. JDNobodi
    JDNobodi 1/2 ton status Premium Member
    Oct 9, 2002
    3,002
    194
    Santa Maria, CA
    I don't know about seriously rusted, but I alternate beating on the arm front to back till one by one the conical washers pop up.
    If everything is really rusted, I would heat the arm up with a torch and spray the studs with WD-40. Be careful, WD-40 is flammable and may catch fire when sprayed on a hot part. Yee-Haa!:eek1::eek::yikes::blush::crazy::D:weld:
    The WD-40 should get sucked down the threads if the part is hot. Now hit the thing again till it breaks loose.
  6. neverendingproject
    neverendingproject 1/2 ton status
    Jul 24, 2005
    1,637
    Tulsa, OK
    I grabbed my conical washers with some big pliers and took them out no prob, then it didnt take much for the arm to come off.
  7. Brocky
    Brocky 1/2 ton status
    May 22, 2005
    1,170
    St.John's Newfoundland, Canada
    Most guys around here (Newfoundland) use a torch to burn it off. We use salt on the roads and it rusts out everything.
  8. MTBLAZER89
    MTBLAZER89 3/4 ton status Premium Member GMOTM Winner
    Aug 14, 2001
    7,272
    236
    Oak Harbor, WA
    Everything mentioned above and hit down not up to unseat the conical washers too.:wink1:
  9. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    I used a 3lb BFH and hit it twice where the first number is and it popped right up :thumb:
  10. tappan
    tappan Registered Member
    Nov 13, 2005
    15
    Denison,Tx
    Just put four inch lift on 78 blazer.
    Take a floor jack and a 6 or 8 inch piece of 2 inch square tubing.Place the jack and piece of tubing underneith the end you disconected from the drag link.Jack it up with a little pressure then use your hammer and strike just behind the studs.They will slowly start to come up. They will have threads on them so use your fingers and twist them out.
  11. blaze4999
    Feb 1, 2006
    14
    Quantico, VA
    thanks for the advice I'm gonna have some fun working on it saturday. Hopefully it won't take all day. I have everything done on my lift except replacing the steering arm.
