Steering arm removal!
Discussion in 'OffRoad Design' started by RIDNHIGH, Dec 1, 2001.
  1. RIDNHIGH
    RIDNHIGH Registered Member
    Nov 7, 2001
    26
    Bismarck, ND
    As I speak Im attempting to take out my factory steering arm.
    How the heck do you get it out? I have removed the drag link and pitman arm now how do i detach the steering arm from the the rest of the assembly?
  2. SlyDog
    SlyDog 1/2 ton status
    Oct 23, 2000
    3,035
    Scottsdale, Arizona
    I used a torch and a BFH. Got it off in about 15 minutes ...
    <font color=green>[​IMG]1977 K5 GETTIN IT AWN[​IMG]</font color=green>
    BUILT NOT BOUGHT
  3. gokartergo
    Dec 2, 2000
    5,855
    Hollister, CA
    I used a torch and a BFH.. And it still took over a hour.Dan
    If it ain't broke.......Don't fix it....
    <a target="_blank" href=http://coloradok5.com/gallery/Gokartergo>KLICK</a>
  4. RIDNHIGH
    Nov 7, 2001
    26
    Bismarck, ND
    ohh yes i see,, well it worked!
    boy that steering arm is a BIATCH!
    thanks.
  5. SlyDog
    Oct 23, 2000
    3,035
    Scottsdale, Arizona
    Anytime bro
    BUILT NOT BOUGHT
  6. 79Beast
    79Beast 1/2 ton status
    Dec 9, 2001
    1,155
    Georgia
    You boys must not have spent your fair share of time splittin up logs for the winter. I removed drag link and bolts then beat it with an 8lb sledge. 5mins later I was brushing off the knuckle and painting it in preparation for the new steering arm. However, tapered wedge locks are a pain.
  7. SlyDog
    Oct 23, 2000
    3,035
    Scottsdale, Arizona
    I live in AZ, so we don't have to split logs [​IMG]
    BUILT NOT BOUGHT
  8. Leadfoot
    Nov 28, 2000
    3,112
    Western Massachusetts
    It all depends too, I have done several. Some were a POC (Piece OF Cake, i.e. 10 mins. or less) and some were a PITA (Pain In The A$$, i.e. 60 mins. or more, I even had one I wacked at with a 10# sledge, air chisel, air hammer, 2 cans of penetrating lube, etc., etc., after a few days I had a friend with a torch come and cut it off which entailed putting in new studs and balljoints thanks to the heat). So it all depends on how lucky you are. The weird thing is I have seen several that look rusted solid and I think they are going to be a pain but they are fairly easy, and some that are clean and look new but are a pain, and then I have had the vice versa versions of each so who knows. $.02.....change please [​IMG]
    See my rig at <a target="_blank" href=http://coloradok5.com/gallery/Leadfoot> click here </a>
  9. BXwildshot
    BXwildshot Registered Member
    Sep 17, 2001
    97
    Bronx , NY
    The three bolts have a split sleeve surrounding them to ensure a snug fit. Find or make a small "chisel" and hammer it in the split it will expand the sleeve and pop it out.
  10. bigbluek20
    bigbluek20 1/2 ton status
    Dec 18, 2001
    119
    Loveland, Colorado
    I put the jack under the end of the steering arm (think I used a short 2x4 or 4x4 to "reach up"), jacked up that entire corner of the vehicle by the steering arm, and then just had to "pursuade" it a little with a 5lb sledge.
    Didn't pop off, just worked its way up. Be sure to keep the jack stand lined up underneath and all body parts clear in case yours does "pop" off.
