Steering arm spacer wanted
Discussion in 'The Garage' started by 300stw, Jun 21, 2004.
  1. 300stw
    300stw Registered Member
    Jul 4, 2002
    51
    Culbertson Montana
    is there a 1 inch spacer available for chevy dana44 steering arm between knuckle and arm. i have a 2 inch arm and my truck shakes tires hard, thanks.....
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    email Sky at Sky Manufacturing. He sells a 1" spacer for around $15 /forums/images/graemlins/thumb.gif
  3. 300stw
    Jul 4, 2002
    51
    Culbertson Montana
  4. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    are you using a stock style Chevy steering or crossover steering? If you are using stock style have you installed a raised steering arm? If you are using crossover is there a reason you need the spacer? Draglink interference with the spring? We need some more info.
    If you are using stock style steering then you and get a raised steering arm to help conpensate for a lift. If that isn't enough you can get a drop draglink to help compensate for larger lifts.
    If you are using crossover steering then as mentioned above Sky Manufacturing sells 1" steering arm spacers and the 1" extended steering arm stud kit you will need to run a spacer with crossover steering.
    Harley
