steering arm studs or bolts?
Discussion in 'OffRoad Design' started by bad_bo_ti, Sep 11, 2002.
  1. bad_bo_ti
    bad_bo_ti 1/2 ton status
    1,027
    OhiO
    is it ok to use bolts with the cone washers for the steering arm or is that not a good idea? thanks Chris
  2. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> I'd say it's a bad idea. They used studs for a reason, and steering is not something to half-ass. </font color>
  3. thebigdaddyof2
    thebigdaddyof2 1/2 ton status
    Dec 28, 2000
    2,053
    St. Louis, Missouri
    When I made my X-over steering arm spacer, I went to Grade 8 bolts with lock washers and locktite....maybe overkill but I wasn't sure. After many hours on the highway and several wheelin trips, I have yet to have one of the three bolts loosen up. Seems to be working out just fine.
  4. bad_bo_ti
    1,027
    OhiO
    you still used the cone washers too right?
  5. thebigdaddyof2
    Dec 28, 2000
    2,053
    St. Louis, Missouri
    Absolutely.
  6. Stephen
    Sep 15, 2000
    4,228
    142
    Carbondale Colorado
    Studs are preferable if you can use them. If you can't get a stud long enough, bolts can work. They basically do the same thing but the studs will have a bit bigger shank and the friction surface is nut to stud, not bolt to knuckle.
