Steering arm studs removal?
Discussion in 'The Garage' started by MTBLAZER89, Mar 30, 2004.
  1. MTBLAZER89
    MTBLAZER89 3/4 ton status Premium Member GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    I have a set of flat tops I found at the JY already machined drilled and tapped. The machined surface is pretty rusty not real smooth. How do I remove these studs to clean up this surface, or will it be ok the way it is?
  2. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    I'd say unless its really pitted its probably OK. If you want to remove them though, put two nuts on each stud and tighten together then get your wrench on the bottom one and back them out.
  3. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    The proper way to remove them is with one of these:
    Craftsman Stud Remover
    1/2 in. drive stud remover. Set, remove headless bolts. Has 5/16 in. to 3/4 in. capacity.
    Sears item #00904458000
    Mfr. model #4458
    $24.99 /forums/images/graemlins/yikes.gif
  4. micah
    micah 1/2 ton status
    Sep 18, 2003
    374
    Austin, TX
    I found plenty of PB Blaster, a healthy dose of tapping on the knuckle with a hammer and a pipe wrench to be the right combination.
  5. k5 krawler 50
    k5 krawler 50 1/2 ton status
    Jan 26, 2004
    1,467
    Gardnerville, NV
    My dad and i tried using one of those stud removers, but we ended up stripping the little threads on the circlular part, so then we had to cut off the studs and drill them out carefully.
  6. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I'd leave them there unless they're broken or the threads are stripped.
  7. mudjunkie 82
    mudjunkie 82 1 ton status GMOTM Winner
    Dec 27, 2002
    11,449
    Cleveland Ohio
    Leave the studs in and have them Sand blasted........
  8. MTBLAZER89
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    So a little rough on that surface will be ok? Just wondering cause I was reading on Sky's site and they said they don't powdercoat their arms because it will leave a cushion between the metals, and I figured it had to be fresh machined /forums/images/graemlins/thumb.gif
  9. MTBLAZER89
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    anyone /forums/images/graemlins/dunno.gif
  10. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    i think the studs in the D44 are pressed in. beat them out with a BFH or a press.
    leave them in and use a grinder with wire wheel, or sand blast them. they may also have a tack weld on the back of them.
    Grant
  11. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    Grant
    They are not pressed in, He is talking about the one where the steering arm goes. They are screwed in.
  12. bluejeep
    bluejeep 1/2 ton status
    Jan 9, 2004
    106
    Des Moines, IA
    I'd also agree that blasting them would be the best method. Quickest too.
  13. Seventy4Blazer
    Apr 21, 2001
    5,634
    Escondido, CA
    yeah, i know what ones he is talking about, but the alst one i had my hands on they were pressed in. BUT it was also just the drivers side. i dunno. ethier way i would leave them in and remove the rust another way. then clean the threads up as well and use extra loc tight.
    Grant
  14. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    D44 steering arm studs are certainly not pressed in. That would be absolute suicide, nobody would build a truck that way.
  15. Seventy4Blazer
    Apr 21, 2001
    5,634
    Escondido, CA
    and how would that be suicide? it makes far mor sense to me personaly. beisdes, i know what i saw and i seen waht i know.
    im just curious on this one.
    Grant
  16. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    It'd be suicide because that is too stressful an application requring too much torque for a press fit stud.
