steering arm studs
Discussion in 'The Garage' started by nerraw117, Nov 21, 2005.
  1. nerraw117
    nerraw117 1/2 ton status
    Jan 5, 2005
    788
    charlotte, NC
    are the three studs that hold the steering arm on the knuckle the same between the dana 44 and the 10 bolt? does anyone know of a manufacter that sells the studs for the 10 bolt, and also what is the easiest way to remove those from the axle? would heating it up with a torch and locking vice grips on it break it loose? (my steering arm is stuck also). thx i am a nutsack.
  2. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
  3. nerraw117
    Jan 5, 2005
    788
    charlotte, NC
    thats for the dana 44. so they are the same? and any ideas on how to remove them?
  4. divorced
    Jul 20, 2004
    5,115
    I think they're the same. and I've never removed any so I can't help you there.
    :o
  5. bigjbear
    Feb 18, 2000
    13,970
    450
    Marietta GA
    To get the arm off take off the nuts and start turning the wheel. Otherwise get out the BFH. If you don't ruin the studs don't touch them.
  6. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    yes the studs are the same between a 10 bolt and a d44. to get the arm off, you have to hit the arm with a BFH at the arch and only down. i just did one yesterday, it was on for 10+ years, and it took me 20 minutes to get it off.
    to get teh studs out, use a stud extractor, vice grips may work, never down it that way though.
  7. Afireinside
    Afireinside Registered Member
    Jan 22, 2005
    61
    Aurora Colorado
    To remove the studs I just tighten two nuts together then only turn the bottom one.
  8. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    Haha, apparently yall dont know his steering arm, with the nuts loose, driving around the block it aint popped off yet, 10lb sledge aint got it off. Ive never seen one this bad.
  9. nerraw117
    Jan 5, 2005
    788
    charlotte, NC
    yea i havent had the nuts on for the last 2 months and i drive it at leastonce a week and still hasnt budged.
  10. Janitorjim8
    Janitorjim8 1/2 ton status
    Feb 21, 2005
    215
    Illinois
    the steering arm is evil. Enough said. lets just put it this way, not to discourage you... probably 10 hours in putting the whole lift on, close to 20 trying to get that damn steering arm off. Eventually just got a new spindle.
  11. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    the one i took off the other day was preaty bad, the last couple i took off only took 10 minutes. this time when my arms got tired, i took the torch and heated the conewashers up till they were cherry red and hit it 3 times and noticed one starting to pop loose. a few more swings that one was out and the others were starting to loosen up.
    a BFH and a torch will get them off.
  12. BigUglyracing
    BigUglyracing Registered Member
    Sep 19, 2002
    12
    Wyoming, Pennsylvania
    steering arm
    I just had the honor of taking the steering arm off of a 1974 dodge 3/4 ton dana 44. It had never been removed and was a pita.
    What i recomend is a good penetrant oil like pb or thrust.
    Clean it with a wire brush spray it and then begin to beat it to death with a bfh.
    If it is really bad like I read it is.
    Spray / Beat/ repeat
    The pb is what helped me.
    Hope this helps.
  13. B_to_C
    B_to_C 1/2 ton status Author
    Jan 15, 2003
    1,861
    In Government Housing
    One entire day of my lift install was dedicated to that damn arm. Sledge hit after sledge hit, until three men had spaghetti for arms...don't give up though. it WILL come off, just give it hell and don't worry about your physical well-being.
  14. Afireinside
    Jan 22, 2005
    61
    Aurora Colorado
    Try taking a screwdriver and hammer and a lot of pb and try to un thread the cones, after a while they try to become part of the threads.DO NOT drive around with no nuts on the arm it will eventually pop off and you will either wreck of have one hell of a time getting it off good luck.
  15. Big Truck
    Big Truck 1/2 ton status
    Feb 19, 2005
    129
    hermiston, OR
    I couldn't get mine off with my BFH and also letting it soak for about a week with pb blaster, finally i got a sledge hammer and gave it a couple of heavy knock and it came right off (needed bigger hammer).
  16. RootBreaker
    Nov 29, 2001
    5,117
    173
    Williamstown, NJ USA
    or how about using a stud remover?
    that is what i used....
  17. Leadfoot
    Nov 28, 2000
    3,112
    Western Massachusetts
    I know the feeling. I done 6 or so and most have been fairly easy. The one on my 80 I tried for 6 weeks to get it off. Ran it with no nuts, emptied a can of PB Blaster, and a can of Zep over that time and no luck even with a heavy duty sledge. My buddy laughed at me so he came over with his torches and heated the snot out of it and it still would not budge with the sledge. After about 3 hours of him trying to remove it with heat, penetrating fluid (hot, cold), and sledging the snot out of it (with no luck and ME laughing at HIM), he finally cut the arm in several pieces with the torch (butchering the studs in the process) and was able to remove it. I had to then remove the studs from the knuckles which was fun because they were all boogered, and then I made the mistake of going to the dealer for the studs, cones, and nuts ($$$$$$$$ I think they did give me a complimentary jar of lube with that one though....).
  18. RootBreaker
    Nov 29, 2001
    5,117
    173
    and they say they are hurting :haha:
