steering arm torque spec needed
Discussion in 'The Garage' started by hunter, May 26, 2005.
  1. hunter
    hunter Registered Member
    Oct 28, 2004
    52
    Houston,Texas
    I need the torque spec for the 3 fastners on the steering arm please. If anyone has this info please reply.
  2. hunter
    Oct 28, 2004
    52
    Houston,Texas
    Anyone?
    Im literally doing this outside right now :D
    I have the front lift on and steering arm on, just need to install shocks and tighten everything.....need this torque spec bad :crazy:
  3. MarcS
    MarcS 1/2 ton status
    Oct 4, 2002
    515
    NJ
    My Chiltons says 90 ft/lbs and to use new nuts.
  4. originalspanksta
    originalspanksta 1/2 ton status
    Jan 31, 2005
    147
    Philadelphia
    not sure of the exact spec but they need to be TIGHT, minimum 100# i think, i didnt ever measure mine, i just cranked on it with a big ratchet and 4 foot pipe till it felt pretty damn tight. never had any problems (which is more than i can say about the rest of the truck)
  5. Executioner
    Executioner 1/2 ton status
    Feb 22, 2000
    1,530
    Temp. Ft. Walton Beach Fl. home=Tucson, Az.
    That's why people have such a hard time taking off the arm. :confused:
  6. hunter
    Oct 28, 2004
    52
    Houston,Texas
    Thanks guys, the fronts all done. I will have to do the rear tomorrow...damn rain :frown1:
    I appreciate the help ;)
  7. mr_clean
    mr_clean 1/2 ton status
    Sep 21, 2003
    348
    Sacramento, CA
    Did I miss something? Rear steering arm bolts? :confused: :confused: :confused:
  8. hunter
    Oct 28, 2004
    52
    Houston,Texas
    lol....I am installing a lift kit which involved removing and installing a steering arm on the front so I needed the torque spec. I finished the front lift, with help from CK5 of course, and couldnt finish the rear lift because it started raining like hell, therefore I will finish the rear lift tomorrow :D
  9. originalspanksta
    Jan 31, 2005
    147
    Philadelphia
    I've never know anyone who had to remove the lifted arm i put on and tightened.....
    the only complaints about arm removal ive ever heard are people removing the STOCK arm, (factory tightened and on the truck for 20+ years...)I never tightened down one of those...... :whistle:
  10. MarcS
    Oct 4, 2002
    515
    NJ
    Anytime :thumb:
