steering arm
Discussion in 'The Garage' started by unclematty, Apr 28, 2004.
  1. unclematty
    unclematty 1/2 ton status
    Jan 24, 2003
    3,164
    SLC UT
    My steering arms are made of 1 1/2 inch cold rolled steel, the ?? is can I bend this stuff to make it fit better? /forums/images/graemlins/dunno.gif /forums/images/graemlins/hack.gif /forums/images/graemlins/weld.gif /forums/images/graemlins/grind.gif
  2. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    Where does it need to be bent? I wouldn't want to force a bend in it as it will creat a stress riser for you to find in the future.
  3. unclematty
    Jan 24, 2003
    3,164
    SLC UT
    I need to make it kinda "Z" shaped to get the angle off the heim joints, needs to drop about 9 inches. /forums/images/graemlins/waytogo.gif
  4. az-k5
    Oct 15, 2003
    2,774
    Phoenix AZ
    Are we talking about the arm or the draglink? You are probably not going to find an extra 9" of anything in the arm. You can bend the draglink but it will change the length if it is already cut and tapped. I assume you are speaking about x-over too.
