steering arm
Discussion in 'The Garage' started by mattm, Sep 22, 2005.
  1. mattm
    mattm Registered Member
    Aug 15, 2005
    9
    phila pa
    I removed the steering arm on my 74 . Is it necessary to replace the nuts and cones and if so where could I get them? thanks!
  2. shane74
    shane74 1/2 ton status
    Feb 12, 2002
    4,100
    Vancouver, WA
    Nuts, yes. Cones, no..unless they are in bad shape. The only place I know of to get them readily is the dealer, MAYBE through Six States Distributors if you have one close to you.
  3. 3rdshiftdesign
    3rdshiftdesign 1/2 ton status
    Feb 6, 2005
    259
    Bucks County, PA
    I like to install fresh nuts and cones, to ensure I never have to deal with a loose steering arm. As Shane said, the cones are dealer only and I think the nuts are 9/16 fine thread. double check that though.
  4. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    Maybe I don't understand, but I think http://www.sky-manufacturing.com has an install kit with studs, nuts, and cones for $29. I always reuse my old ones and have never had any problems.
  5. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    I replaced the nuts, but not the cones as the kit I had didn't come with them. I haven't had a problem yet.
  6. RootBreaker
    Nov 29, 2001
    5,117
    173
    Williamstown, NJ USA
    I swapped studs and nuts to the passenger side.. reused both.. no problems yet.....ord xover..... awwwww so nice :wink1:
  7. mattm
    Aug 15, 2005
    9
    phila pa
    thanks guys . My cones don't look bad. I'm not gonna worryabout it. As for the nuts anyone know the torque specs or should I just hammer it on with my airgun?
  8. cbbr
    Jul 17, 2004
    14,681
    I'm sure that someone will say its wrong, but I just hammered them on with the airgun. they will probably be a joy to get off (again) someday.
