steering arm!!!!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by blazing86, Jun 22, 2001.
  1. blazing86
    blazing86 1/2 ton status
    Dec 24, 2000
    290
    any tips to getting them off?
  2. solowookie
    solowookie 1/2 ton status
    Mar 31, 2001
    3,880
    Wyoming
    I wanted my mechanic and it was pretty amazing. he used this same technic for tie rod ends, drag link ends etc. whatever and they all just came of easy easy easy...
    he took a BIG hammer, and just whacked the thing on the side. All the little shims just came wiggling out. Same with the tie rod ends just hit thim real good with a hammer and they just fell out... etc.
    [​IMG] <font color=blue> Jeff </font color=blue> [​IMG]
  3. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    You could do a search on "steering arm" It's been talked about alot..
    Most people have luck with a BIG hammer,and the use of a torch. Heat will help loosen the bolts and shims...
    <A target="_blank" HREF=http://community.webshots.com/user/vwryda>http://community.webshots.com/user/vwryda</A>
  4. Espen88k5
    Espen88k5 1/2 ton status
    Feb 19, 2000
    981
    Norway
    Yep, wacking it hard with a big sledge will brake free the cones. Think of it as sending shock waves through the steering arm, making the rust let go. Take a look at the pic's on my page if you want, I got lucky with mine i guess.
    link below.
    <font color=red><A target="_blank" HREF=http://www.espen88k5.alloffroad.com>http://www.espen88k5.alloffroad.com</A></font color=red>
  5. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    DON'T USE A TORCH IF YOU CAN AVOID IT. YOU WILL DESTROY YOUR UPPER BALLJOINTS EVEN IF YOU'RE CAREFUL. I'VE DONE IT 3 TIMES.
    Take the nuts off, use a screwdriver to split the washers (hit the screwdriver down the slit with a hammer) then beat the $#@%$@# out of it with the biggest hammer you can. You might be better off removing the axle from the truck where you can really beat on it. They're a real bastard, you just have to fight with it, I'm sorry to say. But the tips I gave you about splitting the washers, avoiding the torch, and giving it a good beating will all help you out.
    Tim
