Steering arm
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by lukerz, Jul 23, 2001.
  1. lukerz
    lukerz 1/2 ton status
    Apr 13, 2001
    109
    Western Mass
    How close is the steering arm to the axle tube on a d44? Mine looks like it coud hit.
    Lukers
    83 K10 from 76 K5 & 83 C10
    Th350 Np203 355 CID
    31 X 10.5
    Plan on 2" body lift
  2. FRIZZLEFRY
    FRIZZLEFRY 1/2 ton status
    Apr 20, 2001
    3,271
    134
    Clovis CA
    Thats the way stock ones are .
    "I AM THE HILIFT KING"<a target="_blank" href=http://community.webshots.com/user/beaterwhang>community.webshots.com/user/beaterwhang</a>
  3. lukerz
    Apr 13, 2001
    109
    Western Mass
    Do they hit?
    Lukers
    Th350 Np203 355 CID
    31 X 10.5
  4. thatK30guy
    Jan 12, 2001
    32,076
    55
    What do you mean "do they hit?" Go check some other trucks around you in town. You will see the stock arm appears pretty close to the tube, but its nothing to worry about.
    If you are concerned whether it will hit or not, get a friend to turn the wheels while you lay down and watch the arm move back and forth.
    <font color=blue>Daddy told me while learning to pee......"if you shake it more than twice, then you are playing with it!!!"</font color=blue>
  5. Leadfoot
    Nov 28, 2000
    3,112
    Western Massachusetts
    It should come real close but not hit, if it does, then chances are you need to replace your balljoints.
    If you didn't build it yourself, how can you call it yours.......?
  6. lukerz
    Apr 13, 2001
    109
    Western Mass
    It just looks close It does not hit when I turn the wheels. I jusrt wanted to be sure that there is no clearence lost when I articulate(I think that is the term?).
    Lukers
    But thanks all who answered
    Th350 Np203 355 CID
    31 X 10.5
  7. Leadfoot
    Nov 28, 2000
    3,112
    If the balljoints are tight, there should never be any difference in clearance whether under articulation or not. The arm is attached to the knuckle which is attached to the tube via the balljoints. Articulating should have no effect on the clearance of the steering arm to the tube, unless like I say you have a worn out balljoints which move when weight is shifted, such as when the vehicle is articulating.
  8. lukerz
    Apr 13, 2001
    109
    Western Mass
    Thank you
    Lukers
    Th350 Np203 355 CID
    31 X 10.5
