Steering arm?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by DesertDueler, Oct 23, 2001.
  1. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    Will a knuckle and steering arm from a ford dana 44 work to do a crossover steering on my Jimmy. If not then where can I get the pass. side steering arm? Also what years are the best to find the flst top knuckle?
    86Jimmy 4"&35"MTRs,87 burb 4"&35"MT,69Firebird w/525 hp,and 70GTO live in PHX,AZ<a target="_blank" href=http://www.geocities.com/modifierperformance>My vehicles</a>
  2. DesertDueler
    May 23, 2001
    3,106
    Phoenix, AZ
    Another question about crossover, can I flip my tie rod bar around and use the hole where the stabilizer use to be as a mounting point for the crossover? The reason I ask is because I have heard it is the weak link, but in the crossover article in the technical section he uses the bar with the tie rod end that has the hole as part of it towards the gear box. If its so weak then why can he use it this way?
  3. DesertDueler
    May 23, 2001
    3,106
    Phoenix, AZ
    top
  4. DesertDueler
    May 23, 2001
    3,106
    Phoenix, AZ
    ttt
  5. DesertDueler
    May 23, 2001
    3,106
    Phoenix, AZ
    once again
  6. K10ANDYKHAMNIC
    K10ANDYKHAMNIC 1/2 ton status
    Sep 17, 2001
    1,962
    Western CO
    the tie rod end with a hole in it is no weaker , its just cosmetics
    WHATS WRONG WITH A 305 ?
    81 K10 GOODYEAR 35" MTRS
    TH350 NP 208
    O R D's axles
    NO BREAKAGE :)
  7. DesertDueler
    May 23, 2001
    3,106
    Phoenix, AZ
    Thats what I tough. So do you guys think it is okay to hook a crossove to the hole on the tie rod bar (flipped to pass side)?
  8. K10ANDYKHAMNIC
    Sep 17, 2001
    1,962
    Western CO
    as a mounting point for what ? the drag link ? its not strong enough for that . fine for a tie rod .
    TH350 NP 208
    O R D's axles
    NO BREAKAGE :)
  9. DesertDueler
    May 23, 2001
    3,106
    Phoenix, AZ
    Why wouldnt it be strong enough for a drag link? I was checking out the article in the technical area and he has his drag link connected to the knuckle, but he uses the tie rod end with the hole to connect it to the knuckle.
  10. K10ANDYKHAMNIC
    Sep 17, 2001
    1,962
    Western CO
    no . thats what i was referring too.
    TH350 NP 208
    O R D's axles
    NO BREAKAGE :)
  11. DesertDueler
    May 23, 2001
    3,106
    Phoenix, AZ
    So far it seems to work on his. He had a flat top knuckle drilled and tapped and put an arm on it. For the crossover link he used a modified tie rod link. He cut it to length and retapped it, and put factory tie rod ends on including the one with the hole. I know it will work this way, but I was wondering if I just can use the tie rod link as the mounting pont or will that be too much stress on it?
