@$!#!$%!%!! Steering Arm!!!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Zebra, Jan 19, 2003.
  1. Zebra
    Zebra Registered Member
    Jul 2, 2002
    25
    Dallas, TX
    I think my steering arm is getting the best of me. After installing a 6" lift, I originally installed a used, dropped draglink, but found out the ends are sloppy so I set about to install the raised arm I also have and put back on the stock draglink. So far no luck with the arm. I have done the penetrating and BFH thing, but it has not budged. I originally put on the oil yesterday, but I suppose I may have to apply more and wait. Maybe heat wil be next. Arrrggg!
    Anyone want to swap a raised arm for a good dropped draglink? /forums/images/graemlins/wink.gif /forums/images/graemlins/k5.gif
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    BFH worked perfect for me when i did mine /forums/images/graemlins/thumb.gif
  3. Pure Insanity
    Pure Insanity 1/2 ton status
    Mar 17, 2001
    4,579
    Dade City, Florida
    When you take the nuts off youll notice that the arm is real thin around the furthest back stud. Leave the nuts on to protect the threads (very loose obviously) and smack the arm at the thinnest point in the back. When the cone starts to raise up smack the next one forward. Keep going up to the 3rd then repeat until the cones are all loose.
    I havent had to use this yet but was told it by a front end guy that has never had trouble removing arms. I told it to a bud, who out of curiousity went out and did it to an extra axle he had out back and said the cones popped right out. No heat or nut buster on them either. He got the arm off dry.
  4. Zebra
    Jul 2, 2002
    25
    Dallas, TX
    I'll have to look at that approach. I imagine that also involves removing the caliper for clearance. If I wasn't so cheap I would leave it on and change the joints on the dropped drag link. /forums/images/graemlins/smile.gif
  5. Pure Insanity
    Mar 17, 2001
    4,579
    Dade City, Florida
    Yeah I think its at least easier to remove it all. Im not sure if its ness. or not. Memory isnt working to swooft tonite, and the Blazer is at the shop so I cant go check it out.
  6. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    I used a BFH and a lot of swear words on mine. If you get real close and curse as load as you can, it will help some. /forums/images/graemlins/grin.gif
  7. smack
    smack 1/2 ton status
    Feb 24, 2000
    277
    Colorado
    Correct me if I'm wrong, but according to my Haynes manual your method is exactly the opposite.
    Here's the quote directly from it:
    "Exercise CAUTION when removing the cones from the arm. They are designed from the factory to release with a force inversely proportional to the loudness and severity of the vulgarity level upon removal.
  8. Sandman
    Apr 15, 2002
    5,653
    Pocatello, ID
    Maybe that was the trouble, I should have wispered my feelings and it would have just popped off! /forums/images/graemlins/grin.gif
  9. smack
    Feb 24, 2000
    277
    Colorado
    Probably, but just remember, "pillow talk" only works if you're sincere!!
    smack
  10. txbartman
    txbartman 1/2 ton status
    Jun 1, 2001
    1,975
    Plano, TX
    I used the BFH approach as well. I removed the tie rod to get me better clearance and smacked the end of the arm with a 4lb mini-sledge. Beat it up a few, then down a few. After some time it popped off.
    No matter what approach, I would definitely take a few things off to give better access to it. No need to try and cram something in there to get at it when you really need swingin' space!
  11. Sandman
    Apr 15, 2002
    5,653
    Pocatello, ID
    Or drunk. /forums/images/graemlins/grin.gif
  12. MJF
    MJF 1/2 ton status
    Nov 1, 2001
    694
    Campbell, CA
    Get one of those little butane heaters, trust me. I took one off without the heat & it took me three days of hitting it with a BFH & using the air hammer to try to loosen it up.
    The next one I tried, I got the heater & it was off in 10 minutes. Just heat it up & whack it.
  13. Zebra
    Jul 2, 2002
    25
    Dallas, TX
    Thanks for all the help guys. pureinsanity's method worked like a charm. After removing the caliper for clearance and giving a few good whacks in the thin area, the first cone started to come out and all was downhill after that...
    Unfortunately, my stock, straight draglink is a tad too lonk even with the ends threaded all the way in, so I may have to shorten it up by removing some of the excess threads.
  14. Pure Insanity
    Mar 17, 2001
    4,579
    Dade City, Florida
    Glad it worked for you. Well thats 2 for 2. Anyone else try it yet?
    Did you do it dry or had you sprayed them down?
  15. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    I just did a steering arm swap. If the drag link ends are meeting in the adjusting sleeve, then you'll probably only be able to turn right. /forums/images/graemlins/shocked.gif To re-center the steering box after the swap you should need to back off the DRE's so that the steering wheel backs off one complete turn. That will give you the ability to turn both left and right. /forums/images/graemlins/cool.gif
  16. BowtieBlazer
    BowtieBlazer 1/2 ton status
    Jul 15, 2001
    2,462
    Baton Rouge, Louisiana
    I have a junkyard axle from an 84 that has the original arm, I'll give it a shot this afternoon....its a little easier since the axle is out of the truck... /forums/images/graemlins/grin.gif
  17. Living Large
    Living Large Registered Member
    Jun 22, 2002
    40
    Central CA.
    Just finished installing a lift on my 91 sub on Sat. Here is what worked best for me. Use your floor jack and apply pressure from under the arm. A piece of square tubbing works well, put the tubbing on the floor jack in the vertical position. When the arm is under pressure, hit the arm from the side, this well pop the tappered cones up. Use a screwdriver and turn(loosen) the cones. They well screw right out of the arm. It is a old forlft trick-many old forklifts use the same method for atttaching the drive hubs.
  18. BowtieBlazer
    Jul 15, 2001
    2,462
    It worked like a charm!!! No lube no nothing....it's supposed to be hard to get the steering arm off? Start to finish around 5 min...4 lb sledge was the weapon of choice /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
  19. Blazinaire
    Blazinaire 1/2 ton status
    Mar 17, 2002
    1,262
    Santa Maria, CA
    everyone has thier theory, but if you want to do it right go find a Snap-On truck and get yourself a cone washer puller . Basically a set of pliers that clamps around the washer and the arm of the pliers goes in the split on the washer and spreads it open, then you just pull them out! I about crapped my pants when my friend brought these over to help lift another friends blazer a few weeks ago, took a whopping 5-6 seconds /forums/images/graemlins/eek.gif /forums/images/graemlins/blush.gif /forums/images/graemlins/cool.gif to remove the steering arm (we dared him to beat our previous record of 3 minutes using the BFH method. /forums/images/graemlins/mad.gif /forums/images/graemlins/tongue.gif)
  20. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    since i advise using new conical washer insert thingys....
    i used my air hammer to get them out. worked great, but i needed new washers. thats how they come out, is by now being able to stay in from being mutilated.
    grant
