steering arm
Discussion in 'OffRoad Design' started by chevystepside, Jul 5, 2003.
  1. chevystepside
    chevystepside 1/2 ton status
    Sep 23, 2002
    147
    leadville colo
    if your steering arm for the x over for a d44 already has 10deg machined into it will i still need to machine the passenger side knuckle to 10 deg.
  2. 4X4HIGH
    Dec 14, 2001
    22,059
    69
    Pleasanton, CA.
    If I understand you correctly the answer is No. You just need to have the passenger side flat top knuckle machined to accept a steering arm that has a taper built into it.
  3. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    The arm has the taper, the knuckle is cut square.
