STEERING ARM
Discussion in 'The Garage' started by 74beater, Aug 15, 2003.
  1. 74beater
    74beater 1/2 ton status
    Sep 20, 2002
    242
    ELGIN ,TX
    HOW DO I GET THE STEERING ARM OFF OF A DANA44
    PLEASE HELP I BANGED ON IT, I GOT IT HOT WITH A TORCH
    ALSO THE ARM IS ORG SINCE 74
    ALL HAIL THE ALMIGHTY SAWZALL
  2. Depdog
    Depdog 1/2 ton status Author
    1,657
    Georgia
    Well for me it was all in how you bang on it with the hammer.
    I hit down on the end where the drag link bolts, then up. Did this for a few min till it loosened up a little.
    Depdog
  3. angrysnowplow
    angrysnowplow 1/2 ton status
    Jan 8, 2002
    502
    MA
    BFH /forums/images/graemlins/thumb.gif
    Try hitting down and side to side. Mine came off with that, and a LOT of penetrating oil in about 15 minutes. /forums/images/graemlins/shocked.gif
  4. 74beater
    Sep 20, 2002
    242
    ELGIN ,TX
    tried it...banged on it for a hour with a 5pd hammer. i've used 3 cans of pen.oil
  5. angrysnowplow
    Jan 8, 2002
    502
    MA
    I was using an 8lb sledge, try a bigger BFH. /forums/images/graemlins/thumb.gif
    Good luck with it.
  6. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    How about one of the ball joint pullers (the tuning fork looking wedge piece, my pop has one on top of his tool box seems about the right size).
    Or an air chisle with the flat blade, point it up if your replacing the arm, stop if its f-ing up the knuckle.
    BFH works too.
  7. BurbLover
    BurbLover 1/2 ton status
    Jul 31, 2001
    3,060
    SW Missouri
    Try hitting the side. It worked for me. I also used ATF instead of pen fluid. I seems to work better for alot of applications. Anyway, just my $0.02.
    /forums/images/graemlins/burb.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/k5.gif
  8. jasonkh2tg
    jasonkh2tg 1/2 ton status
    Mar 27, 2003
    139
    MPLS MN
    completely torch it off then remove the studs if you can or if they break off torch them to but don't damage the threads....Oh and you must go to GM to get the cone washers and make sure to install it with new all metal lock nuts... /forums/images/graemlins/k5.gif
  9. Depdog
    1,657
    Georgia
    Bring it to the house. I got a tool to get it off!!!
    If the sledge wont do it, the plasma will...
    Depdog
  10. bigjbear
    Feb 18, 2000
    13,973
    453
    Marietta GA
    Try hitting up at the bottom of the arm where the DL mounts if you have the DL off already. Also 8 lb hammer w/ a full legenth handle, minium. If its still on, put the tire back on and turn the wheel back and forth a few times w/ the nuts off.
  11. 74beater
    Sep 20, 2002
    242
    ELGIN ,TX
    thanks, guys
