Steering box - arm crossover questions???
Discussion in 'OffRoad Design' started by Tommy, Feb 3, 2002.
  1. Tommy
    Tommy 1/2 ton status
    Feb 21, 2000
    260
    Alabama
    Stephen, I am putting together everything I need to do my crossover setup, I got a ford drop arm from a buddy, but it seems to be clocked a 1/4 turn from the arm I took off the box, which came off a mid 70's 2WD suburban. Have I missed out on something, or am I just looking at it wrong. Thanks, Tommy
    Drive it Like You Hate It!
  2. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    Well, you got the wrong arm. Later model fords are clocked different. Good news it it's really easy to fix yourself. Get a hacksaw or sawsall and a triangle file. Run the saw down the center of each index spline then groove it out with the triangle file to make it look just like the rest. Now you should be able to put the arm on any direction you want.
    It'll take a bit of work to make it fit, but that's the overall plan.
    Making the world better, one truck at a time.
    SW-ORD
    <a target="_blank" href=http://www.offroaddesign.com>www.offroaddesign.com</a>
  3. Tommy
    Feb 21, 2000
    260
    Alabama
    Now why didn't I think of that!!!!!
  4. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    while we're on this subject, just what years of furds will provide a good pitman arm for a x-over setup?
    J
    See the on-going build up of my '85 Jimmy! <a target="_blank" href=http://community.webshots.com/user/jekbrown>http://community.webshots.com/user/jekbrown</a>
  5. thebigdaddyof2
    thebigdaddyof2 1/2 ton status
    Dec 28, 2000
    2,053
    St. Louis, Missouri
    Use a '78 or '79 Ford F150 pitman arm. For 4" (or more) of lift, use the drop pitman arm:
    Trailmaster PA19 from Summit Racing. Costs $65.00.
    thebigdaddyof2
