Steering Box Bolts
Discussion in 'The Garage' started by daleearnhardt01, Aug 12, 2004.
  1. daleearnhardt01
    daleearnhardt01 1/2 ton status
    Aug 29, 2002
    3,223
    Richmond, VA
    Going to do the weld-in and bolt on brace. Anybody know the length of the new bolts needed?
  2. pvfjr
    pvfjr 1/2 ton status
    Feb 10, 2004
    2,425
    Oakridge, OR
    If you're doing them both you'll probably just have to put it all in and see how it looks. I think three of them will just have to be a bit longer, and the fourth even more. Also, I have heard of people taking those little spacers out and using the original bolts. You'll see when you take it apart. Though I don't know how important those spacers are /forums/images/graemlins/dunno.gif
  3. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    those stock spacers don't fit with the bolt in brace.
    i think mine were 2.75 or 3" long. i'd put it all together to see 1st. also i would look into grinding the box and using pinch nuts on the outside.
  4. daleearnhardt01
    Aug 29, 2002
    3,223
    Richmond, VA
    Are these bolts something that I can pick up at Lowes?
  5. or2play
    or2play 1/2 ton status
    Feb 22, 2002
    657
    Yuma, Arizona
    Yep, thats what I did. Take the orignals down to lowes and get some the next size up. Probably will be 1/4 inch longer than your stock ones.
  6. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    I got ones a good 1/2" longer than stock so I could put lock nuts on the outside of the box.
  7. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    The grade 8 bolts for the steering brace kit are 4" long 7/16-14. They are included in the kit (three of them).
    As for the weld patch, I'd personally pass. (been there, done that, wouldn't do it again)
  8. az-k5
    Oct 15, 2003
    2,774
    Phoenix AZ
    Get the weld in kit too. It is worth it. Just be a little patient when installing it.
    Tim, you the only person I have heard advise against this mod, and probably could have easily benifited from it. Perhaps if you had done it before you ripped the whole box thru the frame the kit would have fit better. I am sure that kind of stress will make even the best product fit like crap.
    I say run both kits, use lock nuts on the outside, check the bolts often and have fewer worries while out having fun /forums/images/graemlins/waytogo.gif The whole point is to get out on the trails (tread lightly) and enjoy your rig.
