Steering box bolts
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by newyorkin, Dec 16, 2001.
  1. newyorkin
    newyorkin 1 ton status
    May 8, 2001
    16,555
    157
    Los Estados Unitos
    Hey just figured I'd drop a thought for everyone: Check and torque your steering box bolts!!! I had the front top one fall out last week! Then I checked the rest of the bolts, and each one took a full turn and a half to torque down decently.
    I was wondering why it felt like one day all of a sudden it took over 1/2 turn to make the wheels react, but just figured I'd run the pump too low and wore out the box real fast, so I went and got another box. I only drive it a couple miles a day, and it's usually dark when I am, so I didn't spend a lot of diagnosis time...
    I had to drive to New York today, so thursday night, I finally started looking into prepping for a swap. When I stuck my head under the truck, my jaw hit the floor! The top front mounting bolt was hanging out of the ORD brace by almost half it's length! A little more time and vibration and that puppy would be long gone...
    I tried to bolt it back in, but after trying and trying with no success, I pulled out the bolt and looked at it. Apparently, it gradually came loose, and when it got to about 2 or 3 threads, sheared them out of the box, making it near impossible to re-use that bolt and make significant thread grip. I went out and bought a threaded rod (unfortunately the only compatible fastener), screwed that in way beyond the end of the mounting tap in the cast box (eventualy, I'll grind down a nut and put it on there).
    So check your steering box mounting bolts! Yes, I have the ORD brace and ORD bolts!
    Ratch
    <a target="_blank" href=http://k5.8m.com>k5.8m.com</a>
    Welcome to America.
  2. thatK30guy
    Jan 12, 2001
    32,076
    55
    AND......
    use Lok-Tite on all those bolts, too!!! [​IMG]
    I'm not picking my nose...I'm just pointing at my brain!! [​IMG]
    <a target="_blank" href=http://coloradok5.com/gallery/thatK30guy>The K30 Collection</a>
  3. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    I hear ya!! Mine are perpetually loose - One of these days I'll remember to Loctite them, but until that day comes, I retorque mine about every 6 weeks.
    ......And knowing is half the battle
    <a target="_blank" href=http://pugsley.alloffroad.com>pugsley.alloffroad.com</a>
