Steering box bolts
Discussion in 'The Garage' started by PROFESSORSK5, Dec 23, 2002.
  1. PROFESSORSK5
    PROFESSORSK5 Registered Member
    Dec 19, 2001
    81
    So California
    I am having a problem with the steering box bolts on my 89 k5 silverado. First I sheared a bolt off about six months ago, so I replaced all three bolts with grade 8 bolts. Now I am having trouble with the bolts loosening up about every 2 or 3 months. Does anybody know a fix for this problem? /forums/images/graemlins/k5.gif
  2. outlaw612
    outlaw612 1/2 ton status
    Feb 11, 2001
    2,342
    Springfield, Illinois
    Have you used locktite and/or lock washers?
    If those dont work, take a center punch and hit each bolt end(not the head end), around the outside edge. This will slightly expand the bolt end and wont let it vibrate loose. You can still remove them, but they will have to be replace if you ever take them out.
  3. bigmack
    bigmack 1/2 ton status
    Jan 3, 2002
    478
    Tennessee
    When I repaired my frame I put some red locktite on the bolts before installing them, that was about 6-7 months ago and I haven't had any problem with them yet.
  4. tRustyK5
    Jul 23, 2000
    36,169
    1,372
    E-town baby!
    So you only replaced 3 out of the 4 bolts?
    Rene
  5. PROFESSORSK5
    Dec 19, 2001
    81
    So California
    Thank You
    I will try some Loc Tight and lock washers. /forums/images/graemlins/k5.gif
  6. PROFESSORSK5
    Dec 19, 2001
    81
    So California
    Also I will try the center punch just to make sure they don't come loose again. Thaks again. /forums/images/graemlins/k5.gif
  7. slider
    slider 1/2 ton status
    May 7, 2001
    547
    Whidbey Is. Washington
    Dude,use longer bolts and put a nut on the end of them. Never had another problem. /forums/images/graemlins/thumb.gif
  8. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    There are 4 bolts...one is a bitch to get to...dont know how your supposed to tighten it...did you torque to 80 ft lbs?
    I'm in the process of this but got sick...
  9. PROFESSORSK5
    Dec 19, 2001
    81
    So California
    You guys are correct there are four bolts. I was sure there were three but I looked and there are four. I will take care of this next week. Thanks again for all the suggesstions /forums/images/graemlins/k5.gif
