Steering box brace kit.
Discussion in 'OffRoad Design' started by Blue90, Mar 21, 2007.
  1. Blue90
    Blue90 1/2 ton status
    Aug 27, 2004
    583
    Can the ORD steering box brace kit still be applied after using the weld on frame repair kit? I've just recently discovered my frame getting tiny hairline cracks around the steering box. Is it wise to purchase the weld on repar kit at this point or should i just run a few beads allong the problem areas? :confused:
    -Chirs
  2. Citizen Rider
    Citizen Rider 1/2 ton status
    May 5, 2005
    1,415
    Plano, Texas
    The weld in goes on the outside of the frame, and the bolt in goes inside the frame...So even if you run the weld on, it wont effect the bolt on kit.
    Ive heard of people Drill a hole at each end of the cracks, then fill them with weld. But i do not know the full procedure.
  3. sweetk30
    Nov 1, 2004
    25,534
    531
    horseheads , ny 14845
    best get both and search the garage section tons of info on this in there.
  4. 99GmcClassic
    99GmcClassic Registered Member
    Mar 10, 2007
    97
    Abington, Mass
    Buy both. Drill the end of the crack, fill the hole and crack with weld, weld on frame repair kit, get longer bolts for box brace (now your frame is thicker there) bolt brace on, hammer truck more!
