steering box brace kit ???????
Discussion in 'OffRoad Design' started by ducati-cooter, Apr 27, 2002.
  1. ducati-cooter
    ducati-cooter Registered Member
    Jan 24, 2002
    78
    Madison WI
    I purchased the steering box brace for my 90 k5 blazer. I went to install it this weekend but I could not get the little one to line up with the holes, and the large one I could not get to fit in the location it is designed for due to brake lines and 2 rubber hoses I believe are for the steering cooler. What am I doing wrong.
  2. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    For my 84 I had to move some lines....but that was it. It was tight fit.
  3. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    You're probably fighting with the engine oil cooler. The lines may need to be re-routed or bent around. Brakelines are sometimes a problem but they aren't too bad to get out of the way. The engine oil cooler is a bigger pain. Sometimes the lines just have to be moved. I finally have a vehicle with a factory engine oil cooler to work on so I may have some input on that but it won't be for a while yet, it's still at negative 1" of lift with 28" tires.
  4. CK5
    May 19, 1999
    21,624
    702
    CO
    http://coloradok5.com/ordsteeringbracereview.shtml
    I installed one on my 90, you just have to unbolt the clip that holds the lines to the frame and move them around a little, it will fit, also check out the review above for pics, you may have to start all three bolts a little at a time in order to get the holes lined up, these frames are very flexy and are always moving a little bit.
