steering box brace question
Discussion in 'OffRoad Design' started by PeteH, Nov 17, 2003.
  1. PeteH
    PeteH 1/2 ton status
    Mar 26, 2003
    498
    San Jose
    i'm really sorry if this is a repost...
    my crossmember rivits are a little loose(they move up and down a little when i turn causing the frame to flex open a little) so my trucks' pretty squirly when i try to stop and put weight on the front end.
    do i need to fix the rivivts before i get the steering box brace or will it(the brace) fix the rivit problem? can i just replace the rivits with some grade 8 bolts? oh yea my frame isnt cracked at all.
    '75 Blazer /forums/images/graemlins/k5.gif
  2. big pappa b
    big pappa b 3/4 ton status
    Jan 3, 2003
    6,328
    Falcon, Colorado
    In would say defintely replace the rivets first. The bolts would be a lot stronger than the rivets too /forums/images/graemlins/thumb.gif
  3. PeteH
    Mar 26, 2003
    498
    San Jose
    sounds good..thanx
  4. spearchucker
    spearchucker 1/2 ton status
    Nov 17, 2003
    1,556
    Bay area, CA
    I would install the brace first, loosly though. Some people have noticed that a few of the bolts for the brace may be off because their frame has shifted/flexed. If you loosly install the brace then everything will line itself up. Then replace the rivets with grade 8 bolts using grade 8 nylok nuts. Then torque down the steering brace.
  5. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    If you're willing to get into it a little deeper, you can start welding the frame together. Or at least put some lock welds on it here and there. If you go with the bolts (which is a good method also) make sure you drill the parts out to a close tolerance fit to the bolt and I'd recommend using a metal lock nut instead of the nylock. Either would work but it may be easier to find a high grade metal lock nut.
