Steering box brace
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by '73 K5, Apr 19, 2000.
  1. '73 K5
    '73 K5 1/2 ton status
    1,763
    Kansas
    I just got done putting on the ORD steering box brace I bought over a year ago. Since I'm lifting it in the next month or so, I wanted to protect the frame first. That is such a good idea...It's easy to see how much it strengthens it. And the only real big problem I had was doing the work while still being on crutches.
    I just wanted to let all the "newbies" know how important this it. You may want to spend the money on something else, but if your steering box falls off after you slap your 35's on, you're going to wish you would have done this. Its $100 and a couple hours of work...thats it. Probably even less if you aren't on crutches. lol
    '73 K5
    Chevy good...Ford bad
  2. jarheadk5
    jarheadk5 1/2 ton status
    Mar 6, 2000
    4,389
    PA
    Agreed 100%. Safety-related items should be the <font color=red>FIRST<font color=black> things to be fixed/replaced/upgraded. Steering and brakes should be the first couple items on your list of places to spend your money. Appearance can wait until the truck can stop and turn safely. If you think it's not a big deal, think about this: When I was 14, I watched a pregnant 23-year old woman die, trapped in her car. A truck (big-rig type) hit her head-on because the steering tie-rod broke at an old bent spot. The driver lost control and went into the opposing lane. Closure speed was almost 110 mph. She died while paramedics and firemen tried to rip her car apart to get her out.
    The moral of the story is, spend your money wisely. You may not mind living dangerously, but take a moment to think about the other drivers on the road.
    [​IMG] Semper Maintenance!
    [​IMG] So many ideas, so little money...
  3. BillR
    BillR 1/2 ton status
    Mar 15, 2000
    164
    Flagstaff, AZ
    Is this a total bolt-on, or is there welding and/or drilling involved? Also, is this a better fix than the weld-on kit with the plates?
    Blazin' in Flagstaff
  4. '73 K5
    1,763
    Kansas
    It was all bolt in except you have to drill one 1/2 inch hole in the crossmember. And since you have to drill it from the back you need either a 90 degree drill or a drill adapter. There isn't enough room to fit a drill in there because of the crankshaft pulley.
    I believe this is alot stronger than the weld in plates. Those weld in plates should only be used if the frame is already damaged. I was lucky enough to find a '73 model that wasn't messed up. The reason I say the brace is stronger is the way it triagulates the frame rail with the crossmember. It ties everything in together to combine their strengths. There is pretty much no way the steering box will be able to flex on the frame now.
    I used a review from a Peterson's 4-wheel mag. to help me do the install from a couple years ago.
    '73 K5
  5. Brad
    Brad Registered Member
    Mar 28, 2000
    29
    Little Rock, AR
    Where can I find a brace for my 84 Jimmy?
  6. mudfanatic
    mudfanatic 1/2 ton status
    Feb 18, 2000
    614
    Aloha, Oregon
    what month/ year was the mag? was it 4WOR? or 4x4 power?
    '77 K5
    <font color=red>mudfanatic</font color=red>[​IMG]
  7. chaka73
    chaka73 1/2 ton status
    377
    Southern California
    Hey 73 I agree with you safety is always first, one question why are you on crutches? I was on crutches about 6 months ago I had a knee surgery last Feb. had a ligament replaced and two torn meniscus fixed, in other words I totalled my knee playing soccer just a bad kick a really bad kick but now I guess I'm doing better and hope you get better quick cause I know how it feels I couldnt drive for about 3 months that sucked!!! anyway good luck bud.
    keep blazin !!!
  8. '73 K5
    1,763
    Kansas
    Brad: Autofab and Off-Road Design both make one. Off-Road Design is the best, nice to do business with...thats where I got mine at. Try them at offroaddesign.com or 1-970-945-7777.
    Mudfanatic: January 1998 in Peterson's and May 1999 in 4x4 Power.
    Chaka73: Looks like I did a little better than you did. I install car stereos at a store in town and our garage is really tiny. I pulled a 4 door Buick in, and it left only about 4 inches between his back bumper and the garage door. I couldn't fit through, so I was walking on his bumper to get from one side to another. No big deal...it wasn't hurting his car...the other installers do it, etc. I had walked back and forth about 10 times, but the last ph*cking trip I needed to make was all it took. My left foot slipped in between the bumper and garage door and I fell off sideways. So my foot/ankle couldn't move when I fell. When I was free and hit the floor my legs were pointing straight out, but my left foot was pointing 90 degrees to the left. It looked like something off of a Faces of Death tape or something. It was mucho nasty.
    You know how there are the tibia and fibula in your shin? I kind of shattered one of them around the middle of my shin, and then broke a big piece off the other one down by my ankle. I tore both of the biggest ligaments in the bottom of my leg and severely dislocated it. I've had 2 surguries, still on crutches, haven't gone back to work yet, etc. And to make it even worse, my Blazer is stick, so I couldn't drive it until just a couple weeks ago. At least I have a nice bottle of Lortabs to take the pain away. Later
    '73 K5
  9. chaka73
    377
    Southern California
    Damn 73 that sounds painful but keep it up and you'll get better soon good luck 73.
    keep blazin !!!
  10. '73 K5
    1,763
    Kansas
    Good news dude. I just got back from my surgeon's appointment and I'm done with the crutches!!! X-rays looked good, so I'm limping/walking normally again. That makes it exactly 3 months with those damn crutches...at least its over. I still have to look forward to physical therapy though...
    '73 K5
  11. BillR
    Mar 15, 2000
    164
    Flagstaff, AZ
    My brace arrived yesterday, and I installed it last night. It wasn't bad at all. I was able to get my drill in there without the 90 degree adapter. I have a new steering box ordered, so I'll finish it Wednesday. Great procduct!
  12. chaka73
    377
    Southern California
    Hey Bill where did you order the box from and how much was it?
    keep blazin !!!
  13. shaggyk5
    shaggyk5 1/2 ton status
    1,610
    SE pennsylvania
    ouch. sounds painful. I broke my big toe jumping over my girlfriends couch two months ago, and it still isnt right. okay, i know it doesnt need surgery, but it hurt, and i still cant bend my toe. oh well. good luck without the crutches.
    shaggyk5
    aint nuthin in the world like a heavy chevy!!
  14. mudfanatic
    Feb 18, 2000
    614
    Aloha, Oregon
    I know what kind of pain a toe can cause, I dropped a car battery on my left Toe 5 years ago, last year on my 4th surgery I finally can walk without a limp and so far, knock on wood, since that last surgery I havent had to deal with engrown toenails.
    '77 K5
  15. mudfanatic
    Feb 18, 2000
    614
    Aloha, Oregon
    thanks '73 I found my 4WOR mag, in 4x4 power I was able to find April and June but not May [​IMG]
    '77 K5
  16. BillR
    Mar 15, 2000
    164
    Flagstaff, AZ
    I got my box from Checker, believe it or not. $171 and a lifetime warranty! Can't beat it...
  17. Corey-88K5
    Corey-88K5 1/2 ton status
    720
    Home: Michigan, Stationed: Hill AFB (Home of Moab.
    accident stories
    http://www.geocities.com/corey_perez/dakota/corey.htm
    I win, 8 days in hospital (2 dr's said they don't know how I survived), 3 mo in a wheel chair, broken femur (titanum rod still inside) shattered rt. foot, broken left wrist, unidentifible injury to rt. knee.
    Not bad for "lawn darting" into the side of the truck, and flying head first into the bumper of a oncoming truck to than get ran over by it!
    Corey
    88K5
    [​IMG]<font color=red>Girls Like Guys In Bow Ties
  18. '73 K5
    1,763
    Kansas
    Re: accident stories
    You still beat me, but I also broke my back 5 years ago replacing U-joints in a Blazer. I was in a hurry and didn't apply the E-brake and when I pulled the driveshaft it started rolling down my driveway with me underneath. The front axle crushed me down and broke my back, bruised ribs and a little internal bleeding to top it all off.
    '73 K5
  19. Blazer79
    Blazer79 1/2 ton status
    1,816
    Guatemala, Central America
    My Blazer has the frame cracked already. Do you think that welding it and installing that brace is enough? Or do you think I need to weld the plate as well?
    When I emailed them, they said I needed both. But I'd rather hear it from a fellow Blazerer.
    <font color=black>//////
    What the heck!...Drive it like gas is $0.50/gal!!!
    </font color=black>[​IMG]
  20. K5 NUTT
    K5 NUTT 1/2 ton status
    1,611
    Grand Junction Colorado
    Blazer 79...my 79 had the same problem...i welded in the plate after welding up the crack...then installed the steering brace. Night and day difference! I recommend the whole shabang...its worth the money and you don't have to worry about any future problems!
    AZBLAZER
    1979 K5
    1976 K5 Chalet
    1972 K10 Suburban
