steering box brace
Discussion in 'The Garage' started by Shawns84, Feb 12, 2007.
  1. Shawns84
    Shawns84 Registered Member
    Jul 14, 2006
    33
    vancouver island
    Recently I bought a bds steering box brace. It says to skip weld the thing on. Im wondering why one would skip weld rather than welding around the whole thing... Anybody?
    Also what should i set the toe at? Just put ball joints in and its drivin like a clown... It seems to drive nicer with it toed out a bit... When I had it toed in it chewed up the one bearing pretty good and started back on the death wobble thing...
    Anyways, two birds with one post, i know...
  2. goldwing2000
    goldwing2000 Guest
    Toe should be set to zero, *possibly* a small amount in but zero works best.
    As far as why to skip weld, I would assume to reduce the stress on the frame or to minimize the heat effects.
  3. BigEasy
    BigEasy 1/2 ton status
    Dec 18, 2006
    418
    U-jeen, Oragun
    Skip welding is recommended so that if one weld starts to crack, the crack will not chase around the entire brace.
  4. Chaddy
    Chaddy 1/2 ton status GMOTM Winner
    May 23, 2005
    4,110
    Salt Lake City,Utah
    Yep. Mine is still holding strong 6 years later;)
