Steering Box Brace
Discussion in 'OffRoad Design' started by 76_Cheyenne, Jan 29, 2002.
  1. 76_Cheyenne
    76_Cheyenne 1/2 ton status
    Jan 23, 2002
    285
    Missoula, Montana
    I want to get the steering box Brace from ORD but I need a little push. Has anyone got one on their rig and have they noticed a difference. I think it's important but i'd almost rather spend the hundred bucks on sway bar discos.Anyone got an opinion? Thanks
    Cowboy Up!
  2. AGM73k5
    AGM73k5 1/2 ton status
    1,246
    Portland OREGON
    I bet you'd get a whole lot of flex with a cracked frame and disco's [​IMG]
    Go for the steering brace and just pull your sway bar [​IMG] If you do a search in the main forum you'll find numerous people who swear that the steering box brace was the best thing they ever did to their truck, cracked frame or otherwise.
    -Aaron
    ___ __ _ _ ____ __
    AGM73k5 -- ajgm1@yahoo.com
    Speed limits? <a target="_blank" href=http://www.ibiblio.org/rdu/p-sl.html>http://www.ibiblio.org/rdu/p-sl.html</a>
  3. madmike
    madmike 1/2 ton status
    Jan 23, 2002
    496
    ohio
    I installed ORD's steering box brace on my 1980 Chevy 1/2t 4x4 truck. My frame didn't have any signs of cracking in that area, but with 9" of lift, I didn't want any cracks to start. I feel the brace has helped, and I sense less frame flexing is occuring, which makes me feel more secure. At the same time, I switched from a 4" suspension lift that retained the sway bar to a 6" lift. I removed the sway bar entirely, and I barely even notice it's gone. Bottom line, go for the brace.
    [​IMG]psychoholicslag
  4. K10ANDYKHAMNIC
    K10ANDYKHAMNIC 1/2 ton status
    Sep 17, 2001
    1,962
    Western CO
    just get it and enjoy it , even tho mine cracked after installing it ......its my right foots fault heh heh
    pics page
    <a target="_blank" href=http://www.imagestation.com/album/pictures.html?id=4292257869&show_all=1&start=1>http://www.imagestation.com/album/pictures.html?id=4292257869&show_all=1&start=1</a>
    always gets me home K10 STEPSIDE
  5. Rebel88
    Rebel88 1/2 ton status
    Sep 7, 2000
    1,855
    Richmond, VA
    hey man i was looking at your pics...is that a fixed yoke conversion for a 208 t-case? if it is where did you get it?
    also...nice carnage with the other case...
    Later
    Just tap it in...tappity tap tap...
  6. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    Get it..it makes a big difference...
    Eric
    from Freekmont,CA.
    <a target="_blank" href=http://www.community.webshots.com/user/vwryda>Freedom is a state of mind...</a>
  7. K10ANDYKHAMNIC
    Sep 17, 2001
    1,962
    Western CO
    yeah it is , i work in a machine and welding shop so i made it there . it requires a dodge t case for parts .
    pics page
  8. Rebel88
    Sep 7, 2000
    1,855
    Richmond, VA
    is there any way you could outline what is involved? also what parts i would need? i am definitely looking to do this soon and get rid of the slip yoke...
    thanks
    Later
  9. K10ANDYKHAMNIC
    Sep 17, 2001
    1,962
    Western CO
    ok here goes , u need preferably a whole dodge 208 case and your original chev 208 . take the chev case apart ,take the mainshaft out and set it aside . take the dodge case apart halfway ,split it in the middle , and take the mainshft and strip it , then take the chev parts off the chev shaft and install them on the dodge shaft , this takes awhile use a manual to do this step . then u need to get a hold of or make a small alum bushing to be welded next to the one in the dodge case cuz it is in the wrong place . i used the shattered chev case i had laying around as jig for the placement of the bushing . put the rod in and then the bushing , tack weld the bushing dissassemble and then fully weld it . then u can start putting it all back together . the dodge case doesnt have a support rod hole so u can only use one bolt on it , i spose u could weld another threaded alum piece on for it but eh ... anyways any other questions gimme a holler .. see pics of case half on bench with other piece welded in and the support rod one too and i guess just study em ...
    pics page
