Steering box.... Cross over question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by mpascino, Sep 15, 2001.
  1. mpascino
    mpascino 1/2 ton status
    Jan 1, 2001
    557
    Connecticut
    HI, debating doing cross over. I have a steering box for a mid 80 caddy. For those whose don't know , the car steering boxes bolt up to the wrong side of the frame. Any ever tried taking the shaft out of a car steering box and put it into a blazer box so you can index it at all 4 locations?
    Any info anyone has is appricated
    Thanx,
    Mike
    You call that dirty!?
  2. azblazor
    May 5, 2001
    1,953
    Arizona, Phoenix area
    Don't know if the Caddy shaft will work, my guess is it would. I'm doing crossover also. I just got a 78 chevy p/u 2wd box from the wrecking yard for $25.
    <font color=blue>azblazor</font color=blue>
    <font color=orange> 79 K5 454-FI / 4L80E, NP205, D60, FF14, 4" lift, 9K Warn </font color=orange>
  3. tlarsw
    tlarsw 1/2 ton status
    Jan 12, 2001
    270
    Cameron, NC
    I tried to change the shaft out. Opened it up and looked the inside the box, looked like alot of work. Maybe it was the 2WD box that I had, but I figured for the $20 it cost for a 2WD box at the local junk yard, best just to get one there.
    1986 K10 TPI350/NV4500/Gen2 Doubler/D60(ARB)/14FF(Detroit)/4.56 gears
  4. 1 FN HI K5
    1 FN HI K5 1/2 ton status
    Aug 7, 2001
    465
    Northern CA Out in the stick\'s
    Dont mess with that caddy steering box all you have to do is buy a steering box off a 2 wheel drive chevy my local napa auto parts has them 77-79 part # 27-7512 make sure it has the 3/4 small input shaft. hope this helps.
    I did mine 4 years ago its the only way to go. 1 FN HI K5
    you can see my blazer at htpp:/community.webshots.com/user/1fnhik5
