Steering Box. Enemy?
Discussion in 'The Garage' started by k5freak44, Dec 17, 2004.
  1. k5freak44
    k5freak44 1/2 ton status
    Jun 1, 2004
    2,164
    Plano, TX
    Death Wobble?
    Is it possibe for my steering box to cause the death wobble. I have been trying to get rid of this wobble for years and its gotten very annoying. I have new bjs new pitman arm, new stabelizer, healthy shocks, bearings and tie rod ends. Aligned and balanced last summer.
    The wobble ushally happenswhen im going 20-35mph and i hit a bump or drive on a creace in the road. When it wobbles i can feel play in the steering wheel, but it is not the same play generated by my tires jerking back and forth.
    When i jack up my front axle, and i grab my tire, i can move it with my hands at 3:00 and 9:00. When i move it all my steering system moves and i can see my steering wheel move in the window about a cm both ways. Is this normal?
    If i replace the box will the wobble go away?
    If I need to replace it should i just go with crossover?
    How much does a crossover system cost on average?
    Thanks guys!
    ---John
  2. k5freak44
    Jun 1, 2004
    2,164
    Plano, TX
    ttt anyone?
  3. joefl
    joefl 1/2 ton status
    Aug 18, 2004
    153
    Marianna, Florida
    w
    on my Dana 60 my kingpin bushings were worn out and some other were worn out...i'm getting ready to puton a cross over kit, i think i spent like 800 bucks for all my stuff. that is all new bearing and seals, new HD 2wd steering box, crossover kit, new kingpins bushings, and some misc other stuff
  4. k5freak44
    Jun 1, 2004
    2,164
    Plano, TX
    I really need to know. Can the steering box cause the wobble, and is it supposed to have a little play in it when the engine is off?
  5. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    The box should have a little play at either extreme of the pitman arm's travel and next to none in the center. Has the box been rebuilt recently?
    There is a spec for the adjuster on the top of the pitman shaft. DO NOT adjust this w/o knowing what the spec is, but if it's not right it could be part of your problem.
