Steering box fittings and adapters?
Discussion in 'The Garage' started by Robert79K5, Dec 18, 2004.
  1. Robert79K5
    Robert79K5 1/2 ton status
    Mar 23, 2003
    335
    Douglasville Georgia
    Okay so Im putting a 6.2 in my 1979 Blazer and the doner truck is a 1982 model. Evidently my Blazer uses regular flare fittings on the steering box but the 1982 diesels fittings are shaped different and utilize an o-ring. So does anyone know if there is an adapter out there that will make this work or am I going to have to get new hoses made or buy a new steering box or what? Im sure someone has had this problem before and your solutions or ideas are greatly appreciated.
  2. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    There's a little nut in the back of the power steering pump that the hose screws into. Snag the one out of your donor motor's pump and screw it in, then you can hook up the older style hose to a newer pump.
    I did the opposite to hook up mine, it will work either way. Just make sure box, hose, and that one little nut all match and you're good to go.
