Steering box for crossover ?
Discussion in 'The Garage' started by outlaw612, Oct 7, 2002.
  1. outlaw612
    outlaw612 1/2 ton status
    Feb 11, 2001
    2,342
    Springfield, Illinois
    What year box do I need to look for to do crossover on my 86 K10?
  2. thebigdaddyof2
    thebigdaddyof2 1/2 ton status
    Dec 28, 2000
    2,053
    St. Louis, Missouri
    Don't bother with a whole box. Just find a 2wd shaft and swap it into your box. You don't even have to remove the box from the frame. It's a whole lot easier that way.
  3. 72THING
    72THING 1/2 ton status
    Nov 26, 2001
    501
    Ranburne, AL
    I believe (IF I'm not mistaken) that '81 was the first year they used metric fittings on the power steering lines, so if you want a direct bolt-on, I think you'll want an '81-'87 box.
    Will
  4. 72THING
    Nov 26, 2001
    501
    Ranburne, AL
    I for got about just swapping the shaft. Yes, that would definitely be easier! When I did my crossover, I already had a 2WD box laying around, so I just swapped the whole thing. You can get a 2WD shaft from a '69-'87 box.
    Will
  5. Chaz88K5
    Chaz88K5 1/2 ton status
    2,979
    Stockton/Lodi CA
    it just so happens i have a broken 2wd steering box...the shaft is fine...just one of the ears on the box broke off...if you are interested in it let me know...i can dissasemble it and send ya the shaft or send ya the whole box and you can figure it out on your own
  6. outlaw612
    Feb 11, 2001
    2,342
    My box has some play in it so it needs to be changed anyways. That and the box will already be off to fix the cracked frame. /forums/images/graemlins/mad.gif
    Is there a write up anywhere that tells how to change the shaft? (just incase I get the crack fixed and dont have a 2wd box yet)
    Thanks!
  7. outlaw612
    Feb 11, 2001
    2,342
    How much for the shaft?
  8. outlaw612
    Feb 11, 2001
    2,342
    Thanks, thats what I needed to know.
  9. Chaz88K5
    2,979
    Stockton/Lodi CA
    how about $25 plus ride...but i will be about a week or so before i can get it out of the truck...
  10. TopOff
    TopOff 1/2 ton status
    Jan 16, 2002
    1,760
    Folsom, ca
    I'm second in line.
    TIA
  11. Chaz88K5
    2,979
    Stockton/Lodi CA
    if i dont hear back yea or ney by tommorow its yours top off..since ya live close enough you could prob pick it up
  12. TopOff
    Jan 16, 2002
    1,760
    Folsom, ca
    I'd prefer ship... Unless your in North Stockton / South Sac! /forums/images/graemlins/laugh.gif
  13. outlaw612
    Feb 11, 2001
    2,342
    Go ahead and let Topoff have it, I found a complete box and Im gonna go with it. Thanks anyways!
  14. Chaz88K5
    2,979
    Stockton/Lodi CA
    i live in lodi right off hwy 99...at the hwy 12 west exit..its only a 30min drive from sac..and that is north of stockton...or i can ship it to ya...either way works for me... /forums/images/graemlins/deal.gif /forums/images/graemlins/thumb.gif
  15. thebigdaddyof2
    Dec 28, 2000
    2,053
    St. Louis, Missouri
    The allen head bolt on top of the box is used to adjust the backlash. The teeth on the shaft are tapered.
    Will you make the Midwest K5 Thing Fall Run?
  16. outlaw612
    Feb 11, 2001
    2,342
    Im trying to get the truck ready so I can go to Potosi. I picked up a locked D44 with 4.56's from Neil Sunday and am going to Nebraska this weekend to get my 14FF with 4.56 and discs. /forums/images/graemlins/grin.gif Still gotta fix the frame crack, grind the calipers, weld on some perches, ect. If i can get all my parts, Ill have the whole week before to install everything.
    Im hoping to have the crossover done also.
  17. thebigdaddyof2
    Dec 28, 2000
    2,053
    St. Louis, Missouri
    KEWL, hope to see you and the modified rig there!
