Steering box for x over ?
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by Stroked72Blazer, Apr 6, 2003.
  1. Stroked72Blazer
    Stroked72Blazer 1/2 ton status
    Nov 9, 2002
    352
    Little Rock, AR
    Is the steering box diferant itself or is it just the pitman arm I need from a 2wd?
  2. BobK
    BobK 1/2 ton status
    Oct 5, 2000
    1,604
    Petrolia,Ontario,Canada but working in Port Huron,
    you need a 2wd steering box.It orientates the pitman arm properly.
  3. IGOR
    IGOR 1/2 ton status Premium Member
    May 16, 2000
    2,303
    19
    Damascus, OR
    As far as I can tell, if you just get the steering shaft out of a 2wd box it will work - I will know for sure in 2 weeks! The 2wd shaft is machined so you can orient the pitman arm in 90-degree increments. I bought a Superlift Pitman arm for a '78 F-150 with a 4" drop (Superlift P/N 1104) that fits the 2wd shaft perfectly
    I'm pretty sure they will work though...
    This has been discussed in the "Garage" section a little bit.
  4. Stroked72Blazer
    Nov 9, 2002
    352
    Little Rock, AR
  5. 6869704x4
    6869704x4 Registered Member
    Aug 1, 2002
    42
    NW Fla
    A steering shaft from a later model 2wd box would not work in mine. I found a 71 GMC 2wd and that shaft would have worked. But I swapped the whole box. Dont know what year they changed.
