Steering box / frame crack repair
Discussion in 'The Garage' started by fisher1648, Jul 18, 2002.
  1. fisher1648
    fisher1648 Registered Member
    Jun 20, 2002
    79
    Sierra Vista, AZ
    I started prepping to install the off-road design weld-in frame crack repair plates in my 1987 K5. Seems pretty straightforward but, does anybody have any tips that they learned during (or after) their install that might help out ?? Once it's in - it's in for good !
    Thanks, Eric
  2. landsmasher
    landsmasher 1/2 ton status
    Mar 13, 2002
    4,423
    California, The Blow Me State
    Just follow the instructions to a T. Move everything out of the way. Only weld the cracks on the outside of the frame so it will be easier to put the Brace in if you bought one. If you didn't get the steering brace also, you will later. Use 4 bolts to hold the plate on while welding it. Make sure you V grind the cracks before welding. Make sure you clean everything very well before doing any welding.
    Other than that it's a snap...
  3. Anteak
    Anteak 1/2 ton status
    Nov 7, 2001
    105
    Hemet, Ca.
    Larry, Does this mean that you got yours in. How did the new welder work. Is the Blazer running again????? /forums/images/icons/cool.gif
  4. BigOrange90Jimmy
    BigOrange90Jimmy 1/2 ton status Premium Member
    May 24, 2002
    2,923
    Wilmington, NC
    Yeah, don't expect it to fit. And find you a B.F.H. (Big F****** Hammer.
  5. BILLY RAY
    BILLY RAY 1/2 ton status
    Dec 8, 2001
    1,319
    Austin, Tx.
  6. MudbogAD
    MudbogAD 1/2 ton status
    Jun 29, 2001
    672
    Las Vegas Nevada, US
    My frame is cracked so I need one before I get my new set of tires.
  7. fisher1648
    Jun 20, 2002
    79
    Sierra Vista, AZ
    Thanks for the input -
    Just got done installing the plates. They didnt fit very well at first but after spending an evening "encouraging" and "adjusting" them I won the battle. Took me 2 evenings from start to finish.
    Should I go ahead and install the brace too ? Has anyone had the repair plates crack out just like the stock frame ?
    Thanks again, Eric
